#121
Re: The beginnings of a Megasquirt how-to guide
And they're friggin $90. Eff that noise. For that much, I'll just hack up my spare stock ECU and use the connector from it like they do for the "DIY megasquirt inside stock ECU case" threads. |
#122
pretty sure due to it having 2 electromagnets it's able to act as a stepper motor, by energizing one coil more than the other it can turn in small increments. Or it can hold a position.
Not sure why it isn't a spring/always closed or always open then controlled to idle the car as that would be less complex. Then again, subaru did a lot of things in a complicated way such as the window regulator system haha. |
#123
Wait, you can't use the stock harness/plug to work with the IAT? Doesn't the MAF send the reading through one of the 4/5 wires? |
#124
My friend suggests that you carefully check post 117, where the IACV is carefully described in detail, and note that:-
Only a single inductor is involved, fitted with dual windings, one in reverse of the other. In this way two voltages of the same polarity enable open and closed operation. There is no return spring. The use of a permanent solenoid magnet retains a rotary solenoid in a mean central rest position and enables two variable voltages to move, position and hold the solenoid valve at any desired point, towards open or closed. This arrangement also insurers no voltage, fail safe operation. A balanced pair of NPN and PNP transistors within the TCU, allow a single control voltage, to swing the supply voltage, towards either of the open or closed solenoid windings, via their ground circuits.
#125
#126
#127
where'd you snag that brute from?
I need an engine stand |
#128
Hello Harvey, I am simply a messenger, and you are ALL my friends without differentiation.
Trevor sends this message: "The accused invites those who are interested in facts to make contact by email. --- ralphmedway@gmail/.com" Play it nice, we look up to you guys!
#129
You can hijack one of the MAF wires to run the signal from the IAT, but you will have to cut off the MAF plug to get at the wire. Not for a PNP setup.
#130
Why would you have to do that, why not tap into the signal wire instead? I did it as my 'map' reference wire to my phase 2 4eat transmission. Works like a charm.
#131
You mean use the signal from the MAF as the IAT sensor? I'm not understanding what you mean.
#132
Exactly, doesn't the MAF measure 2 things. Air flow AND air temp? Can't you use the air temp sensor's output and jack into it for the MS?
#133
What I was trying to say you could do with the wiring is splice a connector for an IAT sensor. (I used the GM one.) To save the trouble of running new wiring all the way up there and being able use a pin on the stock ECU plug.
#134
The MS2/Extra does have MAF options. I don't remember off the top of my head but I know one is MAF/MAP, and possibly a MAF all by itself.
That being said, a hot-wire MAF works on temperature to measure flow. It heats the wire to a known temperature, then measures how much energy it takes to keep that wire at that temperature. The air goes past the wire, which cools it. The MAF heats up the wire again, and that voltage is DIRECTLY related to how much air went past the element. This is how a MAF works. It does not have an air temp sensor like you think it does. (Or at least I haven't seen one). |
#135
Hm, there are 2 sensors on our maf's, I thought one was ambient air temp sensor. Maybe I'm wrong.
