#76
Re: The beginnings of a Megasquirt how-to guide
It can be done easily. Why limit yourself by using the stock ignitor that will only work with a handful of coils, instead of using the MS2 to drive ANY coil you would want to swap onto it.
Obviously my first post was aimed at the stock ignitor, and not any ignitor. I simply stated that the MS2 can do it, and it can.
'92 SVX LS Pearl White - 6mt |
#77
Found an MS2 system for 300 shipped on ebay.
Looking more and more likely that's what I'll go with... |
#78
Hell, I tested mine in the parking lot when I got mine. |
#79
#80
It's direct from diypnp, in kit form.
#81
Make sure the DIYPNP kit comes with the nippon denso 76 pin adapter: http://www.diyautotune.com/catalog/d...kit-p-384.html
#82
The megasquirt will not handle "any" coil (or most, if not all coils). It will however handle "any" ignitor. The stock ignitor included. |
#83
No, I think the DIY PNP boards are meant to plug straight into the stock ECU plugs. Like the BOB and ECU combined in the same case. But you should double check that.
#85
Ah, I thought earlier in your thread we discussed this and you said I'd need a diybob to make it truly plug and play?
Now I'm I really need to call diy and ask'em exactly what I need to make it pnp. |
#86
Take a closer look at the DIYPNP kits. I thought they were the MS2 ECU + DIYBOB sold as a package, but it looks like they're combined in one case.
#87
Yer correct.
'OEM ECU Connector to plug right into the factory harness!' |
#88
#89
hey wow there charley, no bashing going on.
#90
To paraphrase:
Hey guys i wanna do this thing. -Hey, you can do this. Nuh uh. -Yeah, let me look for it. -Oh, here it is. That's not exactly what you said! -You can do it. You didn't exactly say that thing I said. -Screw you guys, I'm going home.
