Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 11-11-2012, 07:43 PM
The beginnings of a Megasquirt how-to guide
Some preliminary discussion happened here in this thread (which is informative in general as well): http://www.subaru-svx.net/forum/show...451#post713451
This thread goes over my project/goals, etc and has a little discussion of the megasquirt: http://www.subaru-svx.net/forum/show...t=58090&page=4
Where my project stands right now, I need to make the engine that's currently in the car run on the megasquirt, without necessitating any down-time of the car, since I need it for work/school etc, since my brother is using my other car (the black 97) for the next couple months while he's saving up to buy a truck. Then, after I get that car back, and have moved to the new house, which has a garage, the engine swap and real fun stuff will begin, and the blue/6-speed car will be taken out of daily-driver duty.
I ordered a Megasquirt 3 Extra, a Break-out board, a GM IAT sensor, and some other little odds and ends from DIYautotune.com. Ordered 6 LS2 truck coils from ebay, and got some new connectors for the cam and crank sensors from here, since they were especially old and brittle. If you try hard enough, you should be able to find new OEM connectors online for most of what I connected directly to the megasquirt.
Anyway, here's a run-down of what I've figured out/done so far. I got a spare engine and body harness, and went through and followed the wires back from the sensors/etc to the ECU so I could be sure how everything's connected. Then, some of the wiring to the sensors at the engine, I separated, to connect directly to the Megasquirt, while some things I connected to the break-out board, which plugs in where the stock ECU does. Here's the ECU pinout, and the megasquirt pinouts underneath them:
(from here: http://msextra.com/doc/ms3/hardware.html#wiring)
Here are the wires that I connected to the break-out board (here):
ECU pinout location...........MS3/MS3X # (color)......................break-out board #.......................function
B62 - 23.........................MS37 (purple)................................4T..............................fuel pump relay
B59 - 2...........................relay...........................................1C..............................+12V to power everything
B61 - 16.........................MSX26 (green/orange stripe)............3P..............................Tacho
B59 - 21.........................MS7 (black/grey)............................1T..............................ground for CTS
B59 - 17.........................MS7 (black/grey)............................1L..............................ground for O2 (split from CTS ground)
B59 - 3 .........................MS21 (yellow) ................................1E............................. CTS signal
B59 - 6 .........................MS23 (pink) ....................................1K............................. O2 signal 1
B59 - 5.........................MSX22 (blue/darkblu)..........................1I..............................O2 signal 2
Ok, those are the wires I connected to the break-out board. The rest I wired directly to the megasquirt, to the intake manifold ground (at the back, pass. side of the intake manifold, just above the FPR basically), or to fused +12V supply. The +12V supply I used 2 of the small 4-fuse fuse blocks that's sold at DIYautotune, and each fuse box was connected to a relay, that's activated by the +12V ecu supply in the table above. This provides power to the Megasquirt, the IACV, the injectors, and the coils. The injectors and the coils are each split by bank among 2 fuses (5 amp each for the injectors, 10 amp each for the coils).
For timing the ignition, I am using the 12 tooth crank wheel, which is crank sensor #1 (the one tilted, to the (US) passenger side), and the cam wheel. The cam wheel is read as a single tooth wheel, and the crank angle sensor is 12 teeth, with no teeth missing = should be perfect for sequential COPs on the megasquirt. This is an important factor in whether or not I'd be able to switch back and forth to the stock ECU, because if I had to grind a tooth off the 12-tooth wheel, to do wasted spark, I wouldn't be able to change ECUs without changing out the crank sprocket, which would be hugely impractical.
The pinout for each plug is given below:
*Looking at the connector (not the sensor/device), with the clip side up, and the wires going away from you. Pins are from left to right.*
Device......Position from left to right.....MS wire (color)...Function
TPS..........1....................................MS26 (grey).......+5V reference from MS
TPS..........2....................................MS22 ................signal
TPS..........3....................................ground ...............ground
IACV.........1....................................MS30 (FIDLE)......IAC close
IACV.........2....................................+12V.................+12V to drive IACV
IACV.........3....................................MSX9 (Idle)........IAC open
Crank sensor*.1...............................MS24 (white)......Crank signal
Crank sensor..2...............................MS1 (black)........ground
Cam sensor....1................................MSX32 (dk green)......Cam signal
Cam sensor....2................................Any black ground on the MS main harness...Cam ground
Injectors....1...................................MSX INJ A-F (white/color).....Injector signal (grounded at MS)
Injectors....2...................................+12V at fuse box...................Injector power
IRIS**......1...................................MSX27 (VVT).........Signal (grounded at MS)
IRIS.........2...................................+12V at fuse box (shared with IACV).....power for IRIS solenoid
*The crank sensor should be connected using twisted/shielded wire, to prevent electrical noise. These are given in the DIYAutotune harnesses as such.
**The IRIS I actually haven't hooked up yet, I will need to test and make sure whether this will work in software or not. The VVT pin is a medium-current PWM ground signal, but there is a setting somewhere to change it to on/off instead of PWM, just need to play around with it.
The 2-wire CTS and IAT sensors, can be connected either way going to signal/ground, what's measured is the resistance.
All of the MS ground wires were connected to the intake manifold ground, except one (random) that was split off to provide the Cam sensor ground.
I am going to be using LS2 truck COPs, rather than the stock igniter module and coils. The wiring for the LS2 coils I found here and will follow that: http://msextra.com/doc/ms3/ignition.html#ignout
Spark plug wires I haven't quite figured out yet. I got some make-your-own plug wires at advance auto parts and I didn't notice, but the end that connects to the coil should be different from the end that connects to a distributor, which is what I got. So gotta return those and get some that will work.
If you are going to try using the stock igniter, you're on your own. Matt burned one or two igniters, and then added separate igniters, and in my testing I also burned out an igniter too. I don't know yet what needs to be done exactly, but figure it out.
The MAP sensor vac line is T-ed into the FPR line (easiest line to replace if it were to break.
I haven't removed any of the "definitely not going to be used" wires from the MS loom yet. I will wait until it's running before I start trying to clean up the wiring, which is a huge mess right now. There are wires taped up against things all over the engine bay. I gutted the glove box, and removed the AC evap core, to run my wires through the hole in the firewall that's then exposed. I don't really recommend doing the same, since it kind of FUBARs the whole ventilation system in the car (need to fix the airflow somehow to regain heater core function).
So far I have wired up all the sensors, and the break-out board, but neither the coils or the injectors yet (just no time). The sensors I could test without the car running I tested - the crank and cam sensors synced, I calibrated the TPS.
Tunerstudio has a calibration curve built-in for the GM IAT sensor. The CTS, uses a Bosch NTC calibration curve. I will attach a file with the calibration curve later, it's on the laptop at home. In fact, if you wanted, you could use a spare EG33 2-wire CTS as an IAT sensor, just input that calibration curve instead. Once calibrated, the IAT and CTS readings in tunerstudio were reasonable.
So far, I am using only a base map (.msq file) that someone uploaded to the MSextra forums a while back, that I think is also the one 2006eg33 started with. It can be found here: http://www.msextra.com/forums/viewto...?f=131&t=44607 I will upload the one I modified to match my wiring and the sensors/coils I am using later (slight, but important differences). Don't even attempt to use that one with my wiring. I'm hopeful that that map is close enough to work for me. If not I'll try doing what this guy was apparently able to do and convert one of the maps extracted from a stock ECU to the format that the MS uses, and just run it with that.
*More info to come after I have the injectors and coils wired up and finally try starting it up.*
Old 11-11-2012, 07:44 PM
Re: The beginnings of a Megasquirt how-to guide
Reserved for updates
Update - added NTC calibration curve pdf for calibrating coolant temp sensor.
Added .zipped msq file for what the settings I have so far are.
Old 11-12-2012, 09:41 AM
92 SVX 92 SVX is offline
very nice will be watching this space.
Old 11-12-2012, 05:00 PM
I think this guy got the hex maps from UK Phil's site: http://www.alcyone.org.uk/ssm/ecureverse.html
Maybe Phil or one of the others can help me make sense of that.
Also figured out that "O2 sensor 1" in the ECU pinout should be the right (passenger) side sensor, of bank 1, which is cylinders 1, 3, 5. And O2 sensor 2 is for bank 2.
The fire order is 1-6-3-2-5-4. The MS wiring will therefore be:
Inj/coil...cylinder#
A..........1
B..........6
C..........3
D..........2
E..........5
F..........4
I don't see a way to set up both the stock narrow-band O2 sensors and a wide band, but you can set up two wide-bands. I don't have a wide-band yet, I really need to order one but funds are short ATM, and I'd rather use a pair of wide-bands than a single one. For now I'll probably give it a shot with the narrow-bands.
Old 11-13-2012, 05:32 PM
Well, here's some surprising good news. A buddy from the lab just happens to have an autometer wideband that he's not using. And I checked that it will work with the megasquirt, and it should. So if he'll sell it to me then I should have that going sooner rather than later.
And I just realized that this thread is sorely lacking in pictures, so I'll get on that right away. :P
Old 11-13-2012, 05:41 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Send a message via AIM to Stevebsy Send a message via Yahoo to Stevebsy
Are you tapping into the svx harness for the MS?
I swear I saw a place online somewhere that had the svx ecm connectors, I dont think it was a ms site but another aftermarket ecu. That would make things awfully nice....
Anyway...get those pics up!
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway!
'20 Honda Ridgeline
Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here:
http://www.x35design.com
Old 11-13-2012, 06:02 PM
Technically, you can use the break-out board, which plugs into the body harness in place of the stock ECU, to do everything. So far, I haven't had to alter the body harness at all. However, to facilitate my own understanding and keeping track of all of the wiring, I am only using the break-out board for a few things, and keeping most of it on a separate harness, just for the megasquirt.
What 2006eg33 told me via email that he did was use a spare body harness to get the 4 body-side plugs that plug into the 4 engine harness connectors to do everything. That is a pretty clean way of keeping things plug-and-play, because you can leave the body harness of the car alone. He's got it in a legacy or impreza though.
Honestly, I am kind of shy to take pics of my car because the car itself is in kind of rough shape, and the engine bay is a mess right now because of all the wires all over the place. I have them literally taped up all over the place to keep them put while I'm driving. This would really be a lot easier if I could make the car undriveable for a while until it's finished.
Old 11-24-2012, 12:52 PM
Good news, got it to start on the MS last night. Ran as ****tily as I can imagine, but I was pretty much expecting that. Had a ton of sync loss = not a clean enough reading from the crank/cam sensors. Most of the EJ and EG MS builds I've seen have required one or two resistors either inline or across the signal and ground wires in order to get a clean enough signal for the MS. So I need to figure out the best way to go about fixing that. Still, good progress, and I'm excited that it ran at all.
