Old 08-16-2011, 12:35 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
should i go with this?
http://cgi.ebay.com/ebaymotors/92-93...ht_2743wt_1167
i'm not looking for any upgrades. mine are just shot. this is all 4 pads and rotors. the seller is 99.8% positive.
anyone else care to pitch in a similar priced deal? i could get this on r1 concepts, but they aren't cross-drilled, they're just OEM. plus a little more pricey. all your input, whether telling me to buy it or telling me i'm an idiot, is appreciated. :]
edit: similar posting: http://cgi.ebay.com/ebaymotors/SUBAR...#ht_3584wt_958
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 08-16-2011, 01:43 AM
Re: should i go with this?
What's on your car now? If whatever you're using is "normal" and hasn't gotten warped with your driving style, then you probably can get away with the drilled/slotted Ebay special.
Old 08-16-2011, 06:04 AM
SVX_MY_BABY's Avatar
What he said. $200.00 is a heck of a price. If they don't work out I guess you're out 8 pizza dinners for 2.
Peter
Old 08-16-2011, 07:53 AM
B 4 You's Avatar
#lolsvx
i don't even have a clue. they were "new from the dealer" when i got them, and are warped as hell. i can't stand it. i've heard drilled + slotted help with not warping. is this true or just false marketing? pretty much anything at this point is better...
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 08-16-2011, 08:10 AM
Huskymaniac's Avatar
Uses the ignore feature
I have looked into this warping issue and there are lots of contradicting opinions. People who seem more knowledgeable claim that it is due to overheated pads depositing material onto the rotors when stopped. To avoid that, drilled is supposedly better than slotted as it keeps the rotors and pads cooler. Also, carbon/metal or carbon/ceramic pads are better than straight ceramic because they conduct heat better. Also, DOT 4 brake fluid is supposedly better at pulling heat away from the pad. For the rotors, the vent design is more important than material, if the problem is overheated pads, but some rotors do use higher quality metal. And some also cryo cool the rotors. IF warping is true mechanical warping of the rotors themselves then the quality of metal and cryo cooling would be very important. If not, then it is mainly about getting heat away from the rotors and pads.
It looks like R1concepts sells cross drilled versions of the Centric rotors. Centric uses high quality metal stock. However, it doesn't seem to be made from the cryo-treated centric rotors. Too bad as that would be the best combo for the $$$. For the pads, Hawk HPS pads seem to be the best buy for a metallo-carbon composite pad. When I need to replace my front brakes, that is the combo I am going with.
Tony
Old 08-16-2011, 08:25 AM
XT6Wagon XT6Wagon is offline
There is two different things called "warping" by people. One is actual warping. This can be identified by the lateral forces generated. IE it hammers on the wheel left and right. The second is the uneven deposits/friction of the rotor. This can be identified by while pulling the wheel left and right, it is due to uneven friction between the sides, and there is no "hammering".
I don't have any experience with the SVX having issues with actual warping, and the ueven deposits can be prevented with some care in your driving. Googling can provide some tips by people who deal with brakes more than me.
With that said, crossdrilled is so 1990's. I'm more of a fan of slotted rotors for daily use as they don't weaken the rotor anywhere near as much and are quite good at keeping your pads from glazing.
Old 08-16-2011, 10:42 AM
dbarnblatt's Avatar
I'm looking as something like this:
http://cgi.ebay.com/ebaymotors/92-93...-/160400337353
Stock look with an e-coating (Powdercoated, painted, what have you) centers and vented area to prevent surface rust. Just a cosmetic thing.
I am also considering these:
http://cgi.ebay.com/ebaymotors/ws/eB...m=350483395452
In the USA and still costly with the free shipping. Look nice though.
Old 08-16-2011, 12:21 PM
Brakes are too important to go cheap on (#2 to tires IMO).
If you are worried about cost, get these for the front:
http://www.r1concepts.com/subaru-svx...s-PX.47014.htm
And these for the rear:
http://www.partsgeek.com/pdproducts/...-01120116.html
For pads, get these for the front:
http://www.tirerack.com/brakes/brake...6&autoModClar=
and for the rear get ceramic or composite pads from Akebono, Centric, Hawk or EBC from here:
http://www.partsgeek.com/catalog/199...e_pad_set.html
You can put together a really good, low warping setup in front and a decent but much less expensive setup in the rear.
Tony
Old 08-16-2011, 12:41 PM
Gamesy's Avatar
Gamesy Gamesy is offline
i wonder if they are the same dealer that i got mine from.
i got mine off ebay but i contacted him directly to pic em up, they work great!
Old 08-16-2011, 01:21 PM
i would prefer to buy the rotors and pads locally. then if you ever have a problem it won't be hard for you to return or exchange them. i spent several months trying to get the disc brake australia rotors before i eventually got my money back and took it to napa.
Old 08-16-2011, 01:29 PM
This is true, but I'm doubtful that even really crappy brakes will just up and fail without warning. Especially since one should always start off suspicious of new equipment on a car.
My driving style has done well with my brake setup though (see sig), and that stands as my recommendation. When it's time to do brakes on my black svx, I'll use the same stuff (maybe not the SS brakelines though).
Old 08-17-2011, 12:11 AM
92 SVX 92 SVX is offline
I have ss brake lines from r1concepts, r1 concepts drilled slotted rotors front and rear and r1concepts branded ceramic pads, I paid a total of $318. $230 for rotors pads, $88 for ss lines.
I bought them on specials, after thanksgiving sale, and had a 10 or 15% discount. dont remember exactly how much discount.
Old 08-17-2011, 06:43 AM
Just curious Icicng Y not SS lines on the black car ? Is there a problem with them?
Old 08-17-2011, 12:41 PM
They cost money, and to me it seems like they helped more with the feel of the pedal than the actual stopping ability. The black car is supposed to be the comfortable one, and the blue one is supposed to the sporty one. So no need.
