Old 07-20-2012, 08:22 PM
simboglide's Avatar
simboglide simboglide is offline
Oil Pump
Had low oil pressure, pulled the pump off, 3 loose screws on "impeller" plate. re-secured them , car is all back together, is there a fuse i can pull to only "crank" the engine to get the oil into the pump before actually starting?
Old 07-20-2012, 08:58 PM
Re: Oil Pump
I usually disconnect all of the fuel injectors so that even with spark there is nothing to fire.
I spin them enough to put out the oil light before hooking it up again.
