Changing the alternator tomorrow...
So, when I first loosen the locking nut that secures the tensioner pulley, it says to unbolt it 1 turn at the most. Will it work if I do half a turn? Then when I loosen the tensioner adjustment bolt, are there specific amounts of roations that I need to screw them back to? E.g., should I count how many times I unscrew it, or will it simply stop once it's on?
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Changing the alternator tomorrow...
I've never heard the "one turn" on the locking nut? You'll see that the pulley becomes loose, then stop turning. Before you turn out the long tensioner bolt. Get some penetrating oil on the upper threads. A few inches of the bolt has been exposed to the elements for XX,XXX miles and it tends to get resistant to turning as you get up to the gunk.
Also the easiest way to turn out the tensioner is to put your 12mm socket on the bolt. Then use the longest extension you have or multiple shorter extensions and poke them down below/behind the alt pulley. This will position your ratchet above the AC compressor. It's not a straight shot, so either use a wobbly or hold the socket on the bolt and don't fully insert the extension into the socket.
Second that. A set of unremarkable ratcheting box-end wrenches is one of the better tool investments this non-mechanic has ever made.
dcb |
these did not exist. Now they are my most used tool!
Keith |
Sure, if you want to snap the tensioner bolt.
My friend Moog and I made them from stuff.
We had more time back then.... sigh..... Dating was simpler too. sigh........
