Old 03-23-2011, 03:59 PM
dragoontwo dragoontwo is offline
Re: 92 temp guage almost to the red
There are a few exceptions.... Take my '98 Frontier for example. I run with no radiator fan. Nothing. Year round, from TN to IA and back in the summer with A/C on. Towed a 280ZX from Los Angeles to TN through the mountains. I've been fan free on it for over 5 years with no trouble. That truck has to be at idle for well over 15 mins once warm to even start to heat up past the center of the gauge.
'92 SVX LS Pearl White - 6mt
Old 03-23-2011, 07:14 PM
peace-frog peace-frog is offline
took her for longer drive after i thought my issue was fixed. the whole way out to the dealership the temp stayed at normal. on the way home around 30 mph the temp shot right back up. gave her full throttle and the temp went back to normal. it did this about 3 times and then stayed normal the remainder of the trip. when i give it full throttle and the temp goes to normal it goes there fast about 2 seconds. talked to my mechanic and he said he is thinking its the thermostat sticking. so this weekend should be putting the new one in. about how long does it take to do the thermostat?
Old 03-23-2011, 10:47 PM
Cam Cam is offline
not long. 15 minutes....maybe. jack the car up, drain lower radiator hose, remove thermostat housing, replace thermostat and put everything back. Then refill your coolant.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-23-2011, 11:44 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Yeah it's really easy. Hell, I didn't even jack the car up. I just parked it on a tall curb.
Old 03-24-2011, 12:33 AM
Cam Cam is offline
You said you replaced the water pump, correct? If so, did you use an OEM part? It would make sense that the thermostat could be sticking, or that the pump is not capable of moving an ample amount of fluid. It could be headgaskets, but if it goes away when at a stop and increasing RPM's, I would think it to be pretty unlikely.
I think you are on the right track replacing the thermostat. If that does not work, then I would suspect the water pump. If it was an OEM one, then that could be pretty unlikely as well. But, you never know, weird things happen sometimes.
My .02 cents is replace the thermostat, and report back. Be sure to use the proper gasket that goes around the thermostat, or you will leak from the housing. Should just be 2 10mm bolts holding it to the bottom of the water pump. Located right at the end of the lower radiator hose.
Cam
'92 Ls-L Dark Teal
Old 03-26-2011, 02:23 PM
changing the thermostat in a hour or so just wondering what type of coolant i should get what do all of you guys use?
Old 03-26-2011, 03:59 PM
I would just go with the regular auto parts store coolant, since it's too late to try and get your hands on the subaru coolant, which is supposed to be very good stuff.
Old 03-26-2011, 04:01 PM
Huskymaniac's Avatar
Uses the ignore feature
I had a hard time following the sequence of events. Did you get your fans to turn on when you put the A/C on? At low speed I would make sure those fans are coming on. If they do consistently then you are indeed on the right track.
Tony
Old 03-26-2011, 05:05 PM
i could not get the fans to turn on with just turning on the ac. but i did notice that they do work when the car is running. got under the car today and found a coolant leak by the water pump. even though it was replaced last October, the shop used either aftermarket or remand water pump. so i am going to order the correct parts and have everything installed thursday afternoon. what gaskets and such will i need besides the water pump, water pump gasket, thermostat and thermostat gasket?
Old 03-26-2011, 05:16 PM
Look in the how-to docs under maintenance. Also if you're doing the water pump you might as well do the timing belt too.
Old 03-26-2011, 05:19 PM
ok thanks timing belt was done in october and that was fine only 3000 miles on it since it was done
looked in the how to doc and it says water pump seal but not the gasket i know i need the gasket but do i really need the seal? thats the only part not in stock at subaruparts and wont come by the time im getting the pump and such put it
Old 03-26-2011, 05:29 PM
Then I'd forget it unless you find something wrong with it when you look at it. Were the idler pulleys checked out/changed then too?
Old 03-26-2011, 05:57 PM
from the receipts i have from the po no but i basically want to make it drivable for around 6 months until i get a different daily then i will go though everything and start replacing lots of parts
Old 03-26-2011, 06:36 PM
Have you been losing coolant through the leak? Spin the idler pulleys and see if they make noise. At least that way you'll know if they're getting bad or not, even if you're not going to change them now.
Old 03-26-2011, 06:59 PM
yes i have lost a very small amount of coolant and ill test them tomorrow
