Old 12-22-2010, 06:41 PM
Huskymaniac's Avatar
Uses the ignore feature
K&n Hp-4001
Has anyone tried this oil filter? It cross references with the Purolator 30165 which is supposedly compatible with the SVX.
http://cgi.ebay.com/ebaymotors/ws/eB...4766&viewitem=
It is a larger filter so it should have a higher capacity and lower flow restriction. Not sure if that matters unless one is doing some cleaning using either HM oil or an oil additive.
Tony
Old 12-22-2010, 06:52 PM
Cam Cam is offline
Re: K&n Hp-4001
Try finding a filter compatible with the Porsche 944. Same thread and seal configuration. I think OT discovered they fit. Anyways, it holds more oil as well.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 12-22-2010, 07:58 PM
Re: K&n Hp-4001
And North America!, See, there was this ice bridge from Russia years ago, ( we did not call it Russia back then,) and I was bored and took a little walk!
Old 12-22-2010, 08:06 PM
Cam Cam is offline
Re: K&n Hp-4001
It's just too bad royal purple doesnt offer a filter for a 944...
Cam
'92 Ls-L Dark Teal
Old 12-22-2010, 11:10 PM
Re: K&n Hp-4001
This K&N filter is supposedly a re-badge of the Mobil-1 filter. I am assuming that it is a better filter than the Purolator, which is not a Pure-One. However, if one is changing their oil near the recommended OCI and they are not doing a cleaning cycle of any kind, does it really matter if the oil filter is better?
Tony
Old 12-22-2010, 11:55 PM
Cam Cam is offline
Re: K&n Hp-4001
Can't put a price on peace of mind
Cam
'92 Ls-L Dark Teal
Old 12-26-2010, 01:31 PM
Nevin's Avatar
Nevin Nevin is offline
Re: K&n Hp-4001
Here's an interesting page I found on oil filter reviews.
http://minimopar.knizefamily.net/oil.../opinions.html
Look around there a bit, but it is an interesting read. The first list of filters at the top of the page are recommended ones, and the ones near the bottom are the ones he doesn't recommend. I love that fram is on the bottom, because I've been telling people for years that they are garbage. haha
Anyways, I've always preferred the NAPA filters. Why? For me...
1. easy to get at local napa
2. cheap on my shop account
3. solid reputation as they are made by Wix (the Dana Corporation)
I've got a case of NAPA 1287's in my garage right now. Originally for the Porsche 944, but works just fine with our motor. NAPA was having a filter sale, so I bought a case of 12 for 40% off. I figured that wasn't too bad since this filter can be used on all 3 of my cars.
Jesus is the remedy
2015 Expedition EL Ecoboost
