Old 11-15-2010, 01:05 PM
poweredx2 poweredx2 is offline
Tranny issue
I have not griven my svx in 2 months,so I took the car out for a spin last night.The car drives perfect until you try to pass my car won;t rev pass 4500 on a downshift but drive perfect when you are drive under 4000 rpm.It appears to have a new rev limit of 4500 strange because before I parked it the car rev to 7000.Now if i got the car in park no issue reving or in neutral,I am going to change my tranny fluid and filter first,any thoughts.
Old 11-15-2010, 02:45 PM
immortal_suby's Avatar
Thread Killah
Re: Tranny issue
Does the engine run rough at all when the rpm are high?
Locker Link
2015 BRZ Limited 6MT
Old 11-17-2010, 05:56 AM
Re: Tranny issue
I forgot my gas needle was off,I reset my needle and put some gas in the car it shift all the way to 7000 now.I forgot these cars dont shift past 4500 if you dont have enough gas,thanks for the response.
Old 11-17-2010, 07:26 AM
Re: Tranny issue
How low were you?
Old 11-17-2010, 11:22 AM
Re: Tranny issue
After resetting the hand after a refill I think I was nearly empty.My gas needle was nearly a 1/4 of a tank off,my fuel indicator light is also blown.Car runs great now just got to tighten a few bolts here and there.Driving the svx is still a thrill because its such a headturner.I love my new Genesis but the svx got passion.
Old 11-17-2010, 05:30 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Tranny issue
Are you saying that the ECU rev limits the engine if you are low on fuel? Or the TCU won't shift gear if you are low on fuel? How could either of these units know that you are low on fuel? Is there a wire from the fuel level sensor to either of these units?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 11-18-2010, 01:33 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Re: Tranny issue
Something new. I need to try when I am low on gas next time.
How is the genesis doing? The SVX has more interior space or the genesis coupe? I think SVX has more headroom for the back seats and trunk space than the genesis couple, correct? I like the genesis coupe, too.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
