Old 10-31-2010, 03:19 AM
jeffs92svx jeffs92svx is offline
how many miles can we get
I just bought a 92 claret lsl loaded with 136,000. The car is in great shape except for the clearcoat peeling. I have heard from several places to expect only like 175,000 miles before a rebuild. I know it all depends on how it was taken care of. I thought subarus went for hundreds of thousands like toyotas. The guy i bought this off of had 512K on his last subaru (wasnt a svx). I bought this car really cheap for a work car but the more i find out about it, the more i want to keep it nice and oringinal. I bought it for winter driving to work. I guess these cars go really good in snow. I know my 87 xt turbo was awesome in the snow. Well, does anyone have really high miles on here or has anyone had to rebuild. Thank you.
Old 10-31-2010, 04:21 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Re: how many miles can we get
here:
http://www.subaru-svx.net/forum/show...t=high+mileage
should you worry?
its all depend on how you take care and maintain.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 10-31-2010, 04:41 AM
Thank you very much!
Old 10-31-2010, 12:12 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Another thing to consider is the head gasket. Its 19 years old now and it probably will need to be done soon because of the age.
Old 11-01-2010, 07:20 PM
moepower moepower is offline
One of my 2 1996 svxs has 264345 miles on it and it still runs strong but the transfer is beginning to go out again
Old 11-01-2010, 08:28 PM
Originally Posted by jeffs92svx View Post
I just bought a 92 claret lsl loaded with 136,000. Well, does anyone have really high miles on here or has anyone had to rebuild. Thank you.
Sure, just show up here with a low milage SVX and make us all feel bad!
Other than the head gaskets going bad, and the occasional rod bearing these 3.3s are just freeking WONDERFUL!
I just bought a 226K SVX yesterday, without worries, or a roadtest.
Lady Di takes her 208K SVX on trips with out as much as a quick check over.
Change your fluids.
Don't drive Her hard untill She is warm.
Enjoy!
Old 11-02-2010, 01:52 AM
Change your fluids.
Enjoy!
She has pretty good miles but it sat for a while and the clearcoat is peeling. Not much to look at. THe interior is almost perfect. I bought it for $1500 and new i needed a water pump. So, i got the pump and timing belt and thermostat and as they were putting it on they found a gas leak where the lines go up near the drivers rear tire, a bad ball joint wich i had to order and no telling when it will get here, exhaust leak and the rotors are all scratched up like crazy. If i can get a good driver for under $2500, I will be happy. I just cant wait to drive this thing. Oh, i need 2 new tires too. I really wish the clearcoat looked better.
Old 11-02-2010, 04:13 AM
SSSVX's Avatar
It's AWD so you need to change 4 tires at one time unless you get two matching tires with similar tread left. Otherwise it's not good to the drivetrain.
You can always make it look better later.
-SSSVX
Old 11-02-2010, 04:22 AM
I'm sure as long as they are the same size and the same end of the car they would be fine. 2 of the tires wont pass inspection. I will probably paint the car next year after everything else is done. I am concerned about the mechanical stuff first. I hope to have this car 30 years from now.
Old 11-02-2010, 04:29 AM
No, with Subaru's all wheel drive, having different treads can and will affect the life of the transmission. You need matching size and tread and matching tread depth...
Old 11-02-2010, 04:39 AM
I guess i will have to buy 4 new ones then, that sucks! I've already found a gas leak, ball joint all brakes and rotors are bad. Oh well, looking forward to the finished product.
Old 11-02-2010, 05:10 AM
4 tires are cheaper than a new transmission
Old 11-08-2010, 05:08 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Nate, we are talking total odometer mileage, not gas mileage. As for the tires, the transmission cannot receive extra stress from mismatched tires, the vicous clutch differential (that engages the rear wheels) is what would receive extra stress.
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 11-08-2010, 05:11 PM
Yes, but that will cause the fluid paths to become clogged with material and eventually burn up the transmission. Just ask the many who have run mismatched tires and had their transmission fry after a few months...
and i now see that they are talking about total mileage... Sometimes I'm not fully awake or am thinking of another thread when i respond.... I apologize...previous post now edited
Old 11-08-2010, 05:30 PM
Green1995SVX's Avatar
4 matching tires with equal tread wear is absolutely essential.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
