Old 03-10-2010, 03:35 PM
Oil Change Question
So is it best to get those oil plug crush rings directly from Subaru or can they be picked up at an Autozone?
Old 03-10-2010, 03:50 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Oil Change Question
subaru. you can get a 5 pack much cheaper than 5 seperate ones.
Old 03-10-2010, 04:22 PM
Thanks Ben.
Old 03-10-2010, 04:57 PM
Of course they still charge about a buck apiece.
Old 04-05-2010, 07:34 AM
I finally opened up my package with the Oil Plug Crush Rings today and I was surprised to find that they are metal. I guess I was expecting a rubber ring.
I just want to verify that they are right before I get started.
The package is listed as GSKT-DRAIN PLUG 11126AA000
Old 04-05-2010, 07:46 AM
That is the correct part. They are designed for one-time use.
Old 04-05-2010, 08:05 AM
Thanks
Old 04-05-2010, 09:38 AM
benebob's Avatar
But as long as you have extras that one will never leak. The first time you change it without having a spare it'll leak like the valdez.
Old 04-05-2010, 09:48 AM
I bought 5, for the amount of miles I drive the SVX that should last a year.
Old 04-05-2010, 10:47 PM
Gamesy's Avatar
Gamesy Gamesy is offline
i've never changed mine and never had a leak :P
Old 04-05-2010, 10:51 PM
I have never had a leak, but I do have some just in case.
Old 04-06-2010, 08:27 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Same here. I only change it if it is "weeping" which probably averages every 4 or 5 times.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 04-07-2010, 07:36 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Does FRAM make that special valve for our cars? (the one that uses a hose fitting that opens a spring valve). This would eliminate the crush ring replacement.
Old 04-07-2010, 07:44 AM
Old Fogey
Try this one: http://www.quickoildrainvalve.com/
I have one on my Legacy, been using it for 5 yrs now without a drip. Try the one with a hose nipple, slipping a short length of hose on with the other end in the drain pan. No muss no fuss, and better quality than anything from FRAM, imo.
Glenn
Well heck! I see they don't list fitment for the 3.3L. I just emailed them to inquire about it.
Old 04-07-2010, 09:17 AM
Glenn
I've put a Fumato on all of my Soobs. I have had the same model on my Brat, EA-82 Coupe, XT6, Legacy and SVX.
I have the one with a nipple on my Brat. They don't extend too far, but I would avoid the one with the nipple on an SVX, ground clearance isn't all that much to begin with...
