Old 02-03-2010, 12:18 PM
SVXDRIFTER24's Avatar
SVXDRIFTER24 SVXDRIFTER24 is offline
Send a message via AIM to SVXDRIFTER24 Send a message via Skype™ to SVXDRIFTER24
Help Tightning Crank Pulley
Ok so I am putting a 94 pulley on a 92 and I need help getting the belts loose and also holding the crank from rotating while I tighten it on the pulley onto the crank so if you guys have any suggestions then please let me know ASAP
92 LS-L SilverBlack
Old 02-03-2010, 01:57 PM
Re: Help Tightning Crank Pulley
hi since you dont have the right tool you will have to make the best of it ,over #5 cylinder you will find the access plug for the torque converter ,you can hold it with a socket on the 12 mm bolt or using a angled pry bar to stop it from turning ,both the drive belts adjust very easy ,12 mm swivel socket works well after undoing the lock nuts
charlie
Old 02-03-2010, 03:39 PM
I use a locking chain wrench to hold the pulley braced against an idler.
Chain wrench =
