Old 01-26-2010, 08:59 AM
Gamesy's Avatar
Gamesy Gamesy is offline
need some info for tires
I'm looking at getting a set of getting a set of 17x8" 48mm offset rims for my car for the summer and I dont know what size of tire I should get that wouldnt cause tire rub or issues. Also was wondering what would be a good recommendation for tires for summer rims.
Old 01-26-2010, 10:27 AM
BoxerFanatic's Avatar
Re: need some info for tires
Well, stock size is 215/55R16.
to keep near the same rolling diameter, but plus one inch in diameter, and wider width,
Probably 235/45 or 245/45 17 inch tires on 8 inch wheels. 225 width will also fit, but why have wider than stock wheels, without fitting some nicely wide tires. (although I probably wouldn't push it to 255 width.)
I like Toyo T1-R for summer tires. my SVX came with a set from California... which I switched out to Michelin all-seasons, because it is winter here.
But my wife's Miata wears T1-Rs that I bought for it a few years ago. They are grippy, good with water, not horrendously loud, and they wear forever on the Miata... The SVX will probably wear through them a tad bit faster, due to weighing ~1200lbs more... but they'll probably still do ok.
But lots of folks like Kumhos, Goodyears, BFGoodrich, Bridgestone, Michelin...
I have some General Exclaims, for the Legacy, but they wear a bit fast, and get louder as they wear.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 01-26-2010, 10:36 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Mine came with 225/50R16.
I can vouch for Kumho...... order em from the Tirerack website or call around town for the best price. I think I paid $224 for my set of four Kumho Ecsta AST.
Old 01-26-2010, 10:41 AM
225/45, 235/45, and 245/40 are your best size options. You won't rub at that offset unless you go to monster truck tires.
Old 01-26-2010, 11:56 AM
stock on 97's were 215/55R16s I believe. I just know they changed it up on the 97's
Old 01-26-2010, 12:03 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Alll righht!!
That means my '92 can out maneuver a '97.
1-UP !
Old 01-26-2010, 02:55 PM
Gamesy's Avatar
ya well its a package deal a set of gold rota g-force 17x8 + tires + lugnuts + centering rings is roughly 1000-1100 shipped to my door. the guy was asking me tire size and i wasnt sure what to do with
Old 01-26-2010, 06:01 PM
NeedForSpeed NeedForSpeed is offline
I like 235/45/17, same size oem on some EVOs, I believe on 8". Earlier STIs had 225/45/17 on 8' rims, have some on one of our SVX.
If you get a tire with average treadwidth, you will be fine. A very agressive summer tire, has a bit more width, making it a closer fit.
Diameter is near same as 215/55/16 on 97s, slightly more than 225/50/16. The larger diameter makes the speedo more accurate.
I'm putting some TOYO VERSADO LX tires on a couple of our cars in the next couple of weeks, designed as a top-line touring tire, sizes 235/45/17 and 235/40/18.
Let us know what you choose and how well you like the look.
Ron
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 04-07-2010, 08:29 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Can someone gimme a quick yay or nay on a rim size?
5X114.3 17x7 42mm offset 73mm hub bore
Linky
