Old 01-07-2010, 11:55 PM
Chip Hutchinson Chip Hutchinson is offline
Annoying Tranny stuff
Hi all,
I got my car back from my daughter after 2 years. I have repaired a few items (with help from the group) and now I have moved onto the next problem. The Torque converter lock appears to lock and unlock at freeway speeds under certain loads. On my way home, the converter locks about 2 1/2 miles into the trip. It will unlock and lock several times as the gradient from flat starts to increase for the next hill until it steepens enough, and at that point it locks and remains locked until I approach the crest of the hill. When approaching the crest, as the gradient lessens, the converter will unlock and lock about once every second or two until the gradient lessens to almost flat, at which point it locks again, only to repeat this behavior on the next hill, and the next...
I live in the Seattle area and hills are a fact of life. Any suggestions as to the cause and cure of this annoying little gremlin?
TIA Chip.
Old 01-08-2010, 04:36 AM
Re: Annoying Tranny stuff
If your TPS is out of adjustment it could do that. Check your TPS, I think there are instructions in the How To docs...
Do you have an external tranny cooler? Tranny Temp Gauge? When the ATF gets below 100* the TC will unlock.
Old 01-08-2010, 07:16 AM
dcarrb dcarrb is offline
The tachometer in my silver SVX ticked back and forth like a metronome in a certain narrow throttle range, due to the torque converter locking and unlocking. Replacing the throttle position sensor was the cure.
dcb
Old 01-08-2010, 08:20 AM
Do you have an external tranny cooler? Tranny Temp Gauge? When the ATF gets below 150°f, the TC will unlock.
Fixed it for ya Dave.
Old 01-08-2010, 05:59 PM
When my gauge works and it's cold out, I can feel the TC unlock at when it drops below 100 and lock up once it climbs a little above 100. I have the temp sensor in the output line from the trans.
Old 01-09-2010, 01:43 AM
Thanks Guys,
It looks like an easy test and fix if the TPS is the problem, but I am a bit surprised at the cost of a new one. I am seeing between $150 to $316!!
For what they are (A potentiometer) this is pretty outrageous. I will try to find one in a junk yard with low miles.
I will post results when I have them.
Old 01-09-2010, 01:57 AM
Also check your ATF level. I have had my TC lock and unlock because the fluid was low.
Old 01-11-2010, 05:55 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Hi all, sorry to hijack.
I know I have asked this before, but WHY oh WHY, does the transmission transmit SO MUCH heat into the cabin?? I drove for 2 hours today and by the time I got home, the coins in my ashtray we almost TOO HOT to touch!! I could feel heat blowing around my legs (I had shorts on, no shoes).
I have a MEGA radiator, and transmission cooler fitted, but am still very concerned about this heat issue. The whole centre console seemed hot, including the stock CD and radio unit.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 01-12-2010, 12:21 AM
Hello Group,
I am pleased to report back that my converter lock-unlock problem has been cured by replacing the throttle position sensor.
To everyone: Thank You
Chip.
Old 01-12-2010, 04:19 AM
sowise sowise is offline
Chip did you end up getting one from a junk yard then? or did you end up paying full price for new?
Old 01-12-2010, 04:37 AM
Got one from AAA auto wrecking in Kent Wa.
I put their info in the junkyards/known sources thread.
Oh, it was $25.
Old 01-12-2010, 09:52 AM
Oh, it was $25.
nice find
