Old 10-23-2009, 01:23 PM
Green1995SVX's Avatar
Re: Timing belt broke, caused collateral damage
Originally Posted by kwren View Post
You may blow a head gasket if you run it like that... Chances are that you already have.
Keith
Why would that cause the head gasket to blow? I simply ask because I'm curious.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-23-2009, 02:23 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
lol, Keith's head gaskets blow every time he opens his glovebox. He probably just blew them when he dropped the soap in the shower this morning
Old 10-23-2009, 05:02 PM
I actually loled! Great post.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 10-23-2009, 07:50 PM
kwren's Avatar
kwren kwren is offline
I think it is closing my glove box that does it... I really need to get a stubby Phillips screwdriver and adjust that thing... has to be slammed way too hard.
Keith
Actually, I only had one head gasket blow. The end of my cam shaft was rusted and so was the pin in the pulley. That threw the right side bank out of time and made the engine run badly. I took it to a dealer, and they kept trying different things for 6 weeks and a day.. unable to determine the problem. Finally they ran it so much with that "unknown" condition, that they finally blew the head gasket. Strangely, it was the one on the side with the cam shaft-cam shaft pulley problem.
They tested for the head-gasket problem when they first got it into the dealership, and showed no problem... something about a radiator test... I don't know how that works, but that is what they said. After weeks of messing with it, they finally came up with the 6 week test and found whatever they were looking for in the cooling system.
There you go, smartly paints! YT will tell you that I am Right.
Soooo... that only leaves one option for you... the "W" word
Keith
Old 10-23-2009, 08:34 PM
yt yt is offline
Keith
Keith
I will?? Because that sounds really wrong. Running a cam out of time will not blow a head gasket. The leaks work from the coolant jacks to the cylinder sealing ring, not the other way around
Old 10-23-2009, 10:30 PM
kwren's Avatar
Looks like I need a 2nd opinion!
Keith
Old 10-23-2009, 10:45 PM
kwren's Avatar
Back to serious... I wasn't talking about which way the water flows after the head gasket is blown. Not sure but I would venture a guess that the pressure during the compression cycle combined with ignition could exceed the few lbs of pressure in the cooling system.
There are people on this form that know that the camshaft-camshaft pulley condition can cause the head gasket problem. I expect they will show their intelligent heads at any moment!
Keith
(maybe it was the other Tom, or maybe SVX files)
SoCal LS-L's Avatar
Avalanche Alcyoneer
Keith
And a new set of head gaskets
Old 10-23-2009, 10:46 PM
kwren's Avatar
I was sure YT would know this
Old 10-23-2009, 11:03 PM
yt yt is offline
I understand but the ignition timing was not effected by the cam, so there is no excessive pressure upon combustion.
My point about the HG failure was that failures occur starting in the coolant jacket and work their way to the compression ring. Not from the compression ring to the coolant jacket
Old 10-23-2009, 11:08 PM
svxpert svxpert is offline
<<The end of my cam shaft was rusted and so was the pin in the pulley. That threw the right side bank out of time and made the engine run badly. >>
i can see how the OP would have a problem with his pulley being messed up and not be able to tourque down enough not to move, but if its rusted doesnt that mean it doesnt move out of allignment. i too, am with YT on this, with your engine out of time (tune) you would have risked detonation and possible piston damage i would think before it overheated.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 10-24-2009, 12:31 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Agreed, the dealer told you this because they maybe blew your headgaskets during testing and then blamed your cam problem. Or it was preexisting.
At any rate, I dont think anyone here will attest that slight cam timing problems can blow a head gasket. I think you just got lucky and had both coincidentally. At least we found a relatively common problem with the cams, so diagnosing this will be easier for other members.
Old 10-24-2009, 12:47 AM
When the cams wear out it retards the cam timing.
If the passenger side is retarded it does not affect the ignition timing.
The ignition timing is triggered by the drivers side cam.
One of or 93s, Christine had the first (to my knowledge) recorded worn cam sprocket/cam groove problem and it took forever to locate and repair.
I can not see how a retarded cam timing issue/event would cause a detonation event.
I could be wrong, and if I am please feel free to tell me how or why.
Old 10-24-2009, 06:14 AM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
Where do I start?
Oh, you meant about the CAR?!!
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
Old 10-24-2009, 09:48 AM
michael's Avatar
michael michael is offline
What Potholes ???
Not pointing fingers but this is why we should adhere to torque specs when doing t-belts/reseal.
Wanted: Steering Wheel
