Old 03-02-2009, 01:59 PM
intellibomb's Avatar
intellibomb intellibomb is offline
quick tranny fitment Q (2002 wrx)
hi guys,
i found a good deal on a 2002 wrx transmission (5spd)
and i forgot....
i need:
tranny
starter
clutch
slave cyl
master cyl
flywheel (+bolts)
what i forgot about:
do i need
driveshaft?
differential?
axles?
thanks all!
Old 03-02-2009, 02:41 PM
Re: quick tranny fitment Q (2002 wrx)
Clicky 2345
Edit: I believe that Tom now sells a different pedal setup that works with the stock SVX brake booster/master cylinder, so using a WRX one is not necessary.
One thing I would caution is that the 02-03 WRX 5MT's seem to have weaker second gears than most, I've heard many stories of unhappyness. I don't think it'll be a problem for normal driving, but if you start pushing it you may find it's not completely up to the task.
Old 03-02-2009, 07:57 PM
I'm still running an '02 WRX 5MT in mine. Still no issues to speak of.
You still need a crossmember (TomsSVX or custom)
Old 03-02-2009, 09:56 PM
RoughSilver92 RoughSilver92 is offline
Sorry to hijack, but (Earthworm) for the crossmember, it looks like you cut out a section on the underside of the stock svx crossmember and drilled holes to accommodate the rest of the WRX crossmember. Am I correct in this observation? Just asking because that's what I am planning on doing with mine, and I always feel better knowing something has been done in the past with success before I do it.
