Old 08-01-2008, 08:13 PM
oldss72 oldss72 is offline
Transmission slipping all of the sudden
Hello everyone,
I have had my svx for about 3 months now, and it has been perfect, up until tonight.... I stopped at a light, put it in neutral for 1 second by accident, put it back in drive, and it was slipping ALOT! It was perfectly fine last night, and up until that point. The trans fluid/filter was just changed when I had the front diff swapped due to a bad bearing. Could this be computer related AKA not locking the torque converter fully? It was better for a few mins after sitting for 2 hours, and then it started slipping again. I cannot tell if it is slipping through all gears, since it does not want to build speed at all. I did get home, and did get up to about 40 at one point, however it would slip in any gear, and at all RPM's. I really need some help, as I am 300 miles from home at college... any ideas?
Thanks,
Old 08-02-2008, 01:15 AM
Re: Transmission slipping all of the sudden
Originally Posted by oldss72 View Post
Hello everyone,
Thanks,
Hi Joe, it is defiantly related to oil pressure, looks like you have lost it the forward clutch won't apply. Have you checked the level? Was there some trouble fitting the box before that may have damaged the pump drive?
Old 08-02-2008, 09:05 AM
I checked the fluid, and it does not seem low at all. I had a transmission shop do the front diff swap for me. The fluid is pink and clear, and does not smell, so hopefully that is a good sign. I tried putting in the FWD fuse, and that did not help at all. Does anyone have any suggestions? Is the transmission shot?
Thanks,
Old 08-02-2008, 01:59 PM
w.c.myers w.c.myers is offline
this does not sound good. if tran control module is bad fail safe is 3rd @ rev. fail safe means if pulled tran module out would only have those 2 gears.
Old 09-23-2008, 09:56 PM
apocalixto's Avatar
apocalixto apocalixto is offline
do da stanky leggggg!
Send a message via AIM to apocalixto
This just happened to me today. I couldn't get above 35mph, accept for like one minute where I was going 40. The car would just rev all the way up but not putting any of it to the wheels. i NEED some suggestions as well.
It will get up to like 30-35 no problem...but after that...nothing.
My SVX
94 Bordeaux Pearl LS
MB Quart components and 6x9s, Autotek "Mean Machine" Amplifier, Pioneer D3 Touch Screen Nav/DVD/CD/iPod, 4 10" PowerBass 2XL Subs, Powerbass XA-3000D Monoblock Amp
Flowmaster exhaust, MP 6000K HID w/ clear lenses and '97 style grille, Carbon Fiber Hood w/ scoop (recently painted), 17" Sport Max rims (gunmetal w/ chrome lip), Ground Control Coilovers, Motorsport Crank Pulley, and Green Filter, ARP head studs, GroupN Engine mounts
4.44 AWD swap w/ Quick Change
Old 09-23-2008, 10:17 PM
I've seen a few times now that someone has put the car in neutral at a light, or by accident, or whatever, but when they put it back in drive, the trans is gone. Why would this be a repeating occurance? It has me worried enough that I specifically avoid putting my car in neutral at lights.
Old 09-23-2008, 10:31 PM
If the oil level in the transmission is OK, then it is likely that the high clutch may have gone out.
Check the ATF level first.
Old 09-24-2008, 07:34 AM
mine turned out to be a torque converter... however I am having the transmission rebuilt for good measure
Old 09-24-2008, 02:29 PM
Wolfy's Avatar
Wolfy Wolfy is offline
Send a message via AIM to Wolfy
oohh i hate when that happens! did you accidently hit your hand on the shifter when trying to change the radio station? that seems to happen to me all the time grr usually it slips if i rev to high but i learned a little trick. > if i accidently hit it into neutral, push it all the way into park first, then place it back in drive. it avoids confusing the transmission and stops that awful stuck between gears noise. im actually considering taking out the stock radio and putting in a aftermarket on the top shelf instead of "sucker punching" my shifter all the time lol
