Old 09-08-2008, 10:49 AM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Re: Synthetic Transmission Fluid (ATF)
Originally Posted by Schralper View Post
drain it and don't worry til next change.
make sure to change your ext filter after a few thousand after 1st change.
it not like it's gonna free up more hp.
just be more efficient at putting the hp to the wheels.
get synth in the diffs too.
though the front'll need some sliplock for the lsd.
otherwise it chatters in turns.
Replace the ext filter with another Subaru one, or is there an alternative? Part #'s?
Could you expand on the sliplock at bit? How much of each fluid in the front diff and #'s for both the sliplock and what oil you put in there? Sorry for the dumb questions, but I've never even touched the front diff or sure how to fill it, but I'd like to start doing more of this stuff.
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 09-08-2008, 09:44 PM
Bobb Bobb is offline
Hi OMAR, Just a note on how much. You can't drain all the fluid out with the transmission in the car. The amount given in the owners manual is how much the transmission holds after its made/rebuilt. I think if you measure the fluid you take out and put in the same amount your okay. Also as opposed to the engine dipstick, check your transmission fluid level when its hot. Take care, BOBB
Old 09-11-2008, 12:41 AM
Hondasucks's Avatar
Subaru Technician
If you want all the fluid changed, take it to a Subaru dealer or Subaru shop and have them flush it with a machine, it'll cost ~100-150 bucks, but it's worth it.
As for what fluid to run, I currently have Dexron III in my SVX but I plan on switching to a synthetic once I get an external filter fitted.
As for changing the front differential, it uses like 1.5 pints of 75W90 gear oil, I don't know the exact capacity since we have a bulk tank at work with a dial on it, with a notch on the dial for the front diff capacity, and I can't remember the exact number. Rear diff is pretty easy, take both plugs out, let fluid drain, clean lower plug off, reinstall lower plug, with car LEVEL, pour fluid into TOP hole until fluid is level with lower edge of upper hole, reinstall upper plug. They do not require any LSD additives since it is a viscous LSD.
To drain the front diff, remove the 22mm plug at the bottom of the front diff, it's the finned part of the transmission case, under where the front axles meet the case. There is a sealing washer on it, which you can get from the Subaru dealer for a dollar or so. Fill the front diff through the dipstick tube. (Passenger side of the transmission case) It's a short rod-type dipstick, should have "DIFF" cast into the handle.
1986 VW Jetta
Old 09-11-2008, 10:45 AM
dromano's Avatar
dromano dromano is offline
Per the owners manual, page 10-5: front diff=1.3 qt, rear diff=.8 qt
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 09-11-2008, 03:17 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
If you want your transmission changed, take it to a Subaru dealer or Subaru shop and have them flush it with a machine, it'll cost ~100-150 bucks, but it's worth it.
Fixed your post! Me like Click and Clack, would rather religiously change the fluid then take the chance on a parts replacer who didn't know how to operate the machine or a machine that took all the clutch with the fluid. There is no reason to get all the fluid out unless you've cooked it. For me a tranny temp gauge in my pan tells me when its time. Any time I hit 205 on the gauge.
Old 09-11-2008, 04:09 PM
I haven't switched the trans to synthetic yet, but I am now running AMSOIL in the engine (after a full reseal and new oil pan). 1500 miles since I put it in and it still looks new on the dipstick.
