Old 04-03-2008, 02:35 PM
flowing water noise in dash???
Does any one else get the very noticeable flowing water sound in the dash area when your car is running? I suspect something to do with the heater core/engine coolant but i don't know if it's normal or bad, i don't remember when it started but it's been over a year. also, nothing leaks in or out of the cab and all my fluids are/stay full.
Old 04-03-2008, 04:05 PM
I think it would be the water going to your heater. If you have some air in the line or the coolant is low, it may make that sound.
Old 04-03-2008, 04:45 PM
That's what i was thinking and it really makes sense. I did a rad flush a couple months ago though, it didn't help. Is there any way to bleed air out of that system?
Old 04-03-2008, 04:46 PM
Wikedjuggalo's Avatar
Rebuilding
mine does that too mainly on startup fluid is good just nothing I cared to investigate as it comes form pass side and assumed it was heater/ac related.
When I bought my car it had been sitting for a long time and did that for a while, but it's quiet now.
Old 04-03-2008, 05:28 PM
Zandar's Avatar
Zandar Zandar is offline
Looks and smells great.
I get this every now and again, but not very often. It's usually on startup.
1992 LSL Pearlie: 108k, 15min/$15 mod, Alternator wiring "upgrade," Power Mode switch, K&N drop-in, 4500k 35w low-beam HIDs, 3000k 35w fog HIDs, lots more planned (pending funds, of course)- 4.44 5spd being at the top of the list.
"We laugh at honour and are shocked to find traitors in our midst."
-C.S. Lewis
Old 04-03-2008, 06:23 PM
It may be worse when the weather is cold.
Old 04-11-2008, 09:41 PM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
Look on the passenger side up under the dash and you will see a rubber hose going from the heater/ac box to the floor. This is a drain for condensation but usually clogs up with mold dirt etc. When I pulled mine I drained over a gallon of water from it,cleaned the rubber hose out and the "running water" sound was gone. If you run your AC you should see water dripping from where this hose goes thru the floor, if not then the box most likely has water in it. Also gets rid of some of the musty smell when you run your AC
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 04-11-2008, 10:50 PM
You could blow on the drain hose, and if you hear air bubbling, then you know that the hose is clogged.
Old 04-12-2008, 11:53 AM
demonsvx's Avatar
Uh how did you get your mouth down there to do that Sorry couldnt resist
