Old 04-20-2007, 10:35 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
What's the point of buying a pwr radiator?
Say the stock one works perfectly, and the car never overheats. Would buying a pwr radiator make sense for a daily-driven non-racecar? Even if it does keep the engine cooler, won't the thermostat make it run at a certain operating temp anyways?
Brian
Old 04-20-2007, 10:45 AM
dcarrb dcarrb is offline
I don't have one but think all-metal construction is the biggest selling point. There's no plastic tank to split.
dcb
Old 04-20-2007, 10:57 AM
Ricochet's Avatar
I brought some ham.
svx radiators spontaneously split open?
Brian
Old 04-20-2007, 11:30 AM
From what I've seen the plastic tanks aren't exactly "Lifetime warranteed".
Old 04-20-2007, 12:12 PM
My teal came with a conveniently pre-split top tank when I bought it at <105,000 miles. Judging from the posts I've read, this could be the most common of all SVX afflictions.
dcb
Old 04-20-2007, 12:59 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Mine's been good stock...I think 469 dollars or 599 dollars is a rip off.
1995 Subaru Svx L / AWD
Old 04-20-2007, 01:51 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
i bought mine because my stock plastic tank broke. I could have bought another stock one but I have pretty big future build plans so I wanted a higher performance cooling system. plus its bling bling
[SIGPIC][/SIGPIC]
Old 04-20-2007, 06:12 PM
My OEM radiator broke. New one was like 350 so I said what the heck, I'll pay 600 for one that won't break, and has more cooling capacity, and looks better.
I'm also using the phenolic spacers, which cut off the manifold from the block and I think isolates it from a great deal of what would normally be dissipating heat. The PWR should make up for that.
Old 04-21-2007, 12:06 AM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Mine did about 2 months ago (with 131k miles on her). All of a sudden.. smoke everywhere. I thought of getting the PWR radiator but I am instead going with Motorsport's radiator ($195).
Marisa
Old 04-21-2007, 12:54 AM
n00b on demand's Avatar
The plastic at the top of the radiator is known to crack...many people patch it up but it wont last much longer. The PWR also aides in cooling the tranny better.
Old 04-22-2007, 06:39 PM
The PWR radiator has a multipass cooling tube in it and the stock one only passes through once. The other advantage has already been mentioned - no plastic. You have a couple of choices for a replacement, but there is a reason that the PWR is sold for more - the construction. Some of the members who have installed them have mentioned that the car runs cooler in the summer.
Old 04-22-2007, 07:00 PM
Ricochet's Avatar
I brought some ham.
I'm 5-sped
How? I thought the thermostat keeps the engine at a certain temperature..
Brian
Old 04-22-2007, 07:15 PM
I'm 5-sped
You probably don't need it for the cooler part, but they do spilt in the plastic part.
When the tranny starts to heat up, the radiator does not have enough passes of the fluid to cool it down enough, so continure to heat up.
Old 04-22-2007, 07:21 PM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
Hey big boy, ya know ya want one
Used to have: 1994 Pearlie, 40,945 miles, PWR Radiator, Motorsports Aluminum Crank Pulley, Raceconcepts Stainless Brake Lines, Axxis Ceramic Brake Pads, ATE Super Blue Racing Brake Fluid, Dimpled/Slotted Rotors, BBS STi 17 Silver Wheels, Toyo Proxe4 225/45/17 tires, New Dekka Battery, Unauthordox Racing Oil Cap -- adds 3.14 hp, OEM Coin Holder FFTDS aka Force Field Theft Deterent System. Magnetic oil drain plug, Purolator larger oil filter. Now she's in good caring hands at Earls place.
Old 04-23-2007, 03:31 PM
drivemusicnow's Avatar
Poor College Racer
The SVX cooling system is pretty stout stock. Yes, the radiators spontaneously split open, but an OEM replacement one seems to work just fine.
IMO, unless you're racing the car... you just won't need the bad assness that is the PWR rad.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
