Old 01-28-2007, 03:10 PM
Originally Posted by 1320boy
I think i found the problem. When my car overheated last night again i found that yes one of the fans was not working, BUT when i looked at fuse and touched it it went on but you could see an ark in the fuse which is probably why the fuse blew in the first place. What would be causing that and or would some contact cleaner might solve th issue????
By "an ark in the fuse", do you mean an arc within the plug in link ? If so, the fuse is open circuit with only a small gap in the element. This can happen through corrosion. The fuse will have to be replaced.
If the arcing is below the fuse link and within the socket assembly, you will have to look for a mechanical problem which is causing poor contact. Follow your nose.
Old 01-30-2007, 09:30 AM
1320boy's Avatar
1320boy 1320boy is offline
Team ROUND 1
Send a message via Yahoo to 1320boy
Ok ok ok ok ok ok. i think now its my thermastat. Its still running real hot and even when it starts to get hot the needle will go all the way to the red and go down to normal and go back and forth. Im thinking that the thermastat is the problem. Because water will be coming out of the plastic resivor and make that boiling sound.
Anything eles it might be?????
Old 01-30-2007, 09:30 PM
1320boy's Avatar
Team ROUND 1
bumb
Old 01-31-2007, 05:51 PM
rbalach rbalach is offline
DO NOT DO THIS WHEN THE ENGINE IS HOT!!!
Do the following when the engine is COLD:
- start the car
- with the engine idling, open the radiator cap and see if there are bubbles forming.
- if it is, then you probably need a new headgasket
I saw this happen on my friends civic, he had the headgasket replaced and things have been fine since.
Old 01-31-2007, 10:47 PM
It could be the thermostat sticking closed and only opening erratically. Not so likely, but you should check --- the radiator cap could be not holding pressure properly. Last and worst, refer the previous post re head gasket.
Old 01-31-2007, 11:08 PM
That sounds like what my Taurus was doing, temperature bouncing from hig to normal and back quickly. A new thermostat solved the problem, and a rad flush got rid of the 6 year old coolant to make sure no gunk ruined my shiney new thermostat.
Old 02-01-2007, 02:50 PM
That bit usually happens when there is air in the water passages in the engine. The temperature sender is reading water, needle goes up, temperature sender reads air, needle goes down.
Park the car so that the radiator is the highest point. In the morning when the engine is cold, take the radiator cap off, to check that the water level is right up to the cap, if not fill it up, and check it again the next morning.
Old 02-01-2007, 03:03 PM
It has been reported, "Because water will be coming out of the plastic resivor and make that boiling sound."
This is not a likely indication of an air lock. However if the above is carried out as a precaution, idle the engine while filling slowly, and make sure the heater is on.
Old 02-01-2007, 08:48 PM
1320boy's Avatar
Team ROUND 1
Thank guys i'll try that tomarrow when i get off work. If that does not work then what am i stuck? or if it turns out to be the thermostat where could i buy a new one?? Or should i take it to a dealer???
Old 05-31-2007, 09:25 PM
So was it the thermostat?
