Old 11-28-2006, 12:44 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Air intake hose missing? Help!
I was cleaning my air intake line and noticed I'm missing a hose between two outlets. Tell me if I need this? (item number 2) It looks like a by-pass.
Old 11-28-2006, 12:55 PM
Yes, you need that.
Without it you have unmetered, unfiltered air leaning out your intake charge.
Wey?
Old 11-28-2006, 01:09 PM
dannmarr's Avatar
I work for my SVX
That explains why I have been getting bad performance and a bad O2 code even after changing the sensor. Thanks!
Old 11-28-2006, 03:34 PM
That one feeds the PCV, every bit counts Dan.
Old 11-28-2006, 10:02 PM
dannmarr's Avatar
I work for my SVX
Custom made tool for removing the PCV valve
I came across this problem because I was changing the PCV valve. Good thing I did. Thanks for your responses. I also would like to share my photos of a custom made tool for removing the PCV valve. Tell me what you think.
Old 11-28-2006, 10:15 PM
It has been brought to my attention, by a learned gent, lounging back in his new garage, that the meaning of PCV, may be misconstrued to mean some thing else, as noted here;
Hi Harvey!
Personal Computer Vendetta?
Politically Correct Virgin?
Post Colonial Virginia?
Piece-a Crap (chevy) Vega?
Poly Clorine Vinyl?
HAHAHAHAHAHAhahaha, snort, ha
Please note that the real meaning of PCV is "Probably Clogged Valve".
jk,jk.
Old 11-29-2006, 12:15 AM
I think it is a great idea. Cheap and practical. Pick up a second hand spanner(wrench), contact someone with a gas axe and you are in business. Well worth delaying the job to make one.
Edit P.S. It would be a good idea if you specified the dimension i.e. the points where bends are made, so that others can make one in advance of a job. Easy if you have gas on hand while doing the job, but otherwise a first measure and then get someone to bend, exercise. The details should be included in the "How To" stuff.
Old 11-29-2006, 06:22 PM
jk,jk.
Who was it Harvey?
Old 11-29-2006, 06:28 PM
Who was it Harvey?
I wouldn't like to DOB you in Tom, so I won't say.
Old 11-29-2006, 08:30 PM
Date Of Birth?
Dingo Omlet Babies?!?
Demeted Ostrich Bingo?
Drunk Old Bastages?
Delta Omega Bravo?
Duty, Oner Bound
Diss O Bey?
Old 11-29-2006, 08:35 PM
I Goi It!!!
Diana's Old Boyfriend!!!!!
She told me to say that.
