Old 01-13-2005, 11:11 PM
KCROGUEDOG
Exhaust
I am currently ordering all the parts for my dual exhaust set up. I have ordered 2 dyno max muffers high flow welded(which allow the most airflow thru); 2 BMW schitner exhaust tips and I need some info on a cat. I was looking on buying 2 Random cats. The sight and the company seems like they have a good rep. Has any heard or has these I want to know what they are about. They are $280 pricey a piece. Or help refer me to better converters. Also planned on running 3" pipe. Is this bad or good or go with 2 7/8"?
Old 01-13-2005, 11:16 PM
KCROGUEDOG
This is my first post. 97 Red SVX
Old 01-13-2005, 11:54 PM
mbtoloczko's Avatar
sans SVX
Need more info about your exhaust to give advice. Dual pipes from the manifold back? Cat back?
Mychailo
Visit my locker
Old 01-14-2005, 12:12 AM
KCROGUEDOG
yeah replacing the cats and dual the rest of the way back(no res)
Old 01-14-2005, 05:04 AM
If you are going with true duals, then 3" is WAY too big!
, unless you have other mods, like NOX, turbo, supercharger, stay with 2" id MAX for true duals, and 2.5" id max for a single. You will lose a lot of bottom end if you don't. Tom
Old 01-14-2005, 07:14 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Agreed. For a dual set-up, 3" is way too big. Some big block muscle car guys use dual set-ups with that size piping. For our 'smaller' 3.3L engines, that would be over kill unless going to forced induction...
-Chike
2006 Steel Gray WRX TR (sold)
Old 01-15-2005, 10:12 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
to be honest, Random Technology cats never sold
that well, the best cat for your $ is to buy Carrsound
cats (dist thru Magnaflow too )
The LS1 club in Tx did dyno testing various cats last yr
and Carrsound came out on top.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 01-15-2005, 11:06 PM
BATMAN
I agree that 3" is too big.
For the SVX I think 2 - 2.5" is the best for keeping the weight down, better clearance and for scavenging exhaust gases by maintaining an ideal exhaust flow velocity.
BTW, has anyone tried the Moroso Spiral, Edelbrock Tru-flow and Hooker Header Aerochamber mufflers?
Old 01-15-2005, 11:40 PM
mbtoloczko's Avatar
sans SVX
Might sound a bit too extreme, but the more I read about exhaust systems, the more I convince myself that the primary pipes could be kept as small as 1.5" OD for best all-around performance. For dual exhaust, step up to 2.25" OD at around 35-55" from the exhaust manifold.
Mychailo
Visit my locker
Old 01-16-2005, 05:40 AM
KCROGUEDOG
motorsport ty for the tip on the random cats that can save me alot of money on this project. I want max proformance but I want a truely aggressive sound. What if I went with a 3" inlet and a 3" outlet on the cats (to open the resticted flow more) to a 2 1/2 pipes back to the mufflers.(Dynomax ultra flow welded) Then 3"into mufflers and out to tips. Would that be ok to go from 3" to 2 1/2 to 3" and out? I figure the bigger the pipes the deeper the sound. Or use 3" to 2 3/4 to 3" or not. I know you all suggested smaller I just want to here alot of different opinions. 97 red in the beginning stages (off the record it has been -50 for 6 days strait.)
Old 01-16-2005, 10:54 AM
NapaBavarian's Avatar
Good morning!
As I recall someone went to duals before and said it sounded whiney and ricey, basically turns it into t 1.65L engines so you might want to find out what the outcome has been from previous people.
.Karl.
Old 01-16-2005, 10:58 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Does Alaska have yearly emission inspections? You might want to consider just running a single high flow cat (I got a Magnaflow piece from Dayle's shop) around 60-70 inches back from the engine. Since I'm reading the same theoretical info as Mychailo ( ), I'd also recommend keeping the size of your primary pipes small in order to keep your engine's bottom end performance (see Tom's comment above). The Subaru engineers did a good job with the exhaust manifolds and you can basically look at the engine almost as two 3 cylinder engines. You might want to consider going with primary pipes of around 1.5 inches I.D. feeding into a Magnaflow high flow cat with 3 inch inlet and outlet (the cat would serve as your expansion chamber) and then running 3 inch pipe back to the tips you want.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-16-2005, 09:33 PM
wawazat??'s Avatar
Yeah, I'm still around
Originally posted by mbtoloczko
...but the more I read about exhaust systems, the more I convince myself that the primary pipes could be kept as small as 1.5" OD for best all-around performance.
Scientific Desing of Intake and Exhaust Systems??
New Christmas book Mychailo?
Todd
Down to none
Old 01-16-2005, 09:53 PM
mbtoloczko's Avatar
sans SVX
Todd
Yeah, that was some good bedtime reading. :-) I thought I had it all figured out after I read that book. Then I stumbled across this article:
http://www.cafefoundation.org/aprs/EPG%20PART%20IV.pdf
Seems to suggest that mass velocity is far more effective than sonic reflections at generating a vacuum at the exhaust valve in the latter part of the exhaust stroke. Unfortunately, the article doesn't go into enough depth to get sufficient info to accurately apply the concepts to the SVX.
Mychailo
Visit my locker
Old 01-16-2005, 11:41 PM
SVXRide's Avatar
Todd,
1. Smith & Morrison - Gods of Exhaust Design!
2. Aren't you supposed to be on vacation?
Mychailo,
Think we should start welding up an R&D exhaust with "blind legs"?
Did you catch the "...single most effective way to increase the Subaru horsepower output..." comment in the article?
I've got to read the article a couple more times - I'm still wrestling with the tuning for sea level and tuning for 8-12k feet of altitude info presented (as I really don't have any desire to yank the engine out of my car and put it into a plane )
-Bill (ready to weld up an R&D "chamber/muffler", just waiting for the signal....)
