Old 02-26-2011, 05:11 PM
clarkerussell clarkerussell is offline
Does the radiator need to come out for a Timing Belt replacement?
Hello all,
I just completed the valve cover gaskets (I found it to be quite easy, just time consuming) and I am planning to spend tomorrow working on the timing belt/cam seals/oil pump seals/water pump/etc.
I have a very basic question... Does the radiator need to come out make room for working on the front of the engine? Thanks.
Clarke
Old 02-26-2011, 05:22 PM
Re: Does the radiator need to come out for a Timing Belt replacement?
Yes, you will want to take it out so that you have more room.
Old 02-26-2011, 07:22 PM
kwren's Avatar
kwren kwren is offline
I simply just take out the cooling fans... The radiator is not really a bother for me.
Keith
Old 02-26-2011, 10:24 PM
I hate to sound stupid, but does the upper radiator hose need to be removed?
Old 02-26-2011, 11:47 PM
To remove the rad? Might as well. You could leave it attached on the motor end, but it's an extra five seconds to remove it completely and it'll give you more room to work on the belt.
Old 02-27-2011, 07:20 AM
I don't remove the radiator to do a SVX Timing elt, unless I'm doing a water pump at the same time
Old 02-27-2011, 07:34 AM
I'm sorry, I meant if I don't remove the radiator, does the upper hose still need to be removed (and therefore the coolant) to get to the timing belt.
I think the answer is that I need to drain the radiator, and remove it since I was planning on replacing the water pump.
Thanks.
Old 02-27-2011, 07:13 PM
I ended up draining the radiator and pulling it. MUCH easier and it gives me a good reason to replace the coolant. Is there any specific coolant that I should be using, or will any decent name brand coolant from the auto parts store work? Thanks!
Clarke
