Old 02-02-2008, 08:54 PM
SuberNatural SuberNatural is offline
Question 245/45 r16 tires on stock rims
Hey, I was wondering if anyone had gone that wide? I really dont want/need tires this wide but I can get a GREAT deal on them new.
Basically just want to know if the rim is wide enough and if I will have any clearance issues?
225/50R16
245/45R16
Section Width: 8.85 in 225 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 16 in 406.4 mm
Rim Width Range: 6 - 8.5 in
Rim Width Range: 7.5 - 9 in
Overall Diameter: 24.85 in 631.19 mm
Overall Diameter: 24.68 in 626.87 mm
Sidewall Height: 4.42 in 112.26 mm
Sidewall Height: 4.34 in 110.23 mm
Radius: 12.42 in 315.46 mm
Radius: 12.34 in 313.43 mm
Circumference: 78.06 in 1982.7 mm
Circumference: 77.53 in 1969.2 mm
Revs per Mile: 837.0
Revs per Mile: 842.7
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.4 mph 100. km/h
Speedometer Difference: - Speedometer Difference: 0.681% too fast
Diameter Difference: - Diameter Difference: 0.69%
The numbers look close but I havent brought the car home yet (or ever owned an svx before) and the car needs tires.
Thanks in advance,
Mike
Old 02-02-2008, 09:49 PM
That is my preferred size for 16s on an SVX!
No problems.
They might be a little wide for the SVX rim as it's a, well I forgot what its width is. 7" or 7.5"?? I think it's a 7.5" which could work.
245/45/16 has always been my favorite size tire for some reason. If I were you I would go for it. Others may not agree though.
blk 92' LSL w/ average mods
Old 02-03-2008, 12:15 AM
Nevin's Avatar
Nevin Nevin is offline
245/45-16 is the tire size that the good Lord intended for this car when he conjured it up at the beginning of time. It will work perfectly.
I have that size on my FD rims, but it will also work fine on the stock rim.
It is a bit harder to find tires this size, but if you already have some located you've already solved that problem.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 02-03-2008, 11:23 AM
Thanks for all the positive replies guys! Its been a lot of help
Old 02-03-2008, 02:41 PM
Nevin's Avatar
What tire are you planning on getting, by the way?
Jesus is the remedy
