Bearing failure or ?
When overtaking a large truck I suddenly detected vibrations I haven't felt before. This was at the bottom of a mountain pass and then there was gravel road and other awful conditions. When we started the downward slope, my breakes started squeeking a bit. I thought maybe they were a bit overheated.
The problem is still around but in low speeds I keep here in town it's not so pronounced. We are visiting my mother who's had Subarus since early 80s and she thinks it's the front bearing. In short, there's a bit of vibration in the steering wheel, in the chairs and some occational squeeking from the left front wheel. What's your take?
I got my girl, I got my glass, I got my car and I'm ready to f... |
Re: Bearing failure or ?
Wheel bearing failure usually becomes noticeable as a whine or roaring sound that changes in pitch and volume with variations in speed. As failure progresses, the noise increases. Seems unlikely this is your problem.
Possibly you've warped a brake rotor? dcb |
It's possible you have a piece of gravel lodged in the LF brake caliper, causing the squeal. I would get the front end in the air, pull the wheels and give the brakes a good look for wear, and grease the slide bolts.
Glenn
Keith |
Wheels tight? Had the car worked on recently?
2nd on the warped rotor....
Yes, it was subject to a "safety check" a week ago while I had the rallye lights removed. I could always take the wheel on and off. I can probably borrow a torque wrench from my mom's neighbour. How much should I use on the wheels?
As for warped rotor.. why should there be vibration while I'm not braking if the rotor is warped?
I agree rotor . With disk brakes the puck ( brake pad) is in constant contact with the rotor. If the rotor is warped the caliper will wobble. Some cars will actually have a continuous chirping noise when you drive. That wheel weight or something ( stone or foregien object ) stuck somplace on the wheel has some merit also .
Maybe I'm just a bit of a hypocondriac but after driving 500km yesterday I feel pretty sure there's an extra sound that wasn't there before. A bit like a droning sound.
Is there any way to visually inspect the bearings to see if they're done for? Since I'm changing brake discs, should I just have the bearings replaced at the same time in order to save work time?
Feel your wheels after you driven for a while, if one of them is a lot hotter than the others, you probably have a brake caliper sticking, which will warp the new rotor in short order if not addressed...
Well I took a small mountain drive and tried out Power - brake - Power - brake etc. The wheels are studded and didn't feel very hot, neither rubber nor rims. So I dared myself to lightly tap the rotors and while the difference wasn't exactly huge, I'm fairly sure the RF which is where the occational whine comes from was hotter. Difficult to say by light tapping, but quite sure.
Rotor will aways be hot after use. You should touch as close to the hub as you can . Be carful touching rotor .Temp. can easily be 300 deg or hotter after braking. Could cause sever burns.
Actually drive around trying not to use your brakes as much as possible and test to see how warm the hub gets. Last edited by Conn SVX; 04-10-2012 at 03:38 PM. |
I tapped them lightly and I didn't get a burn
Just to clear up a misunderstanding.. by wheels, you mean alloys or the rubber? cheers
