Old 03-17-2006, 03:11 PM
dwd1985 dwd1985 is offline
I broke this hose...part number?
While attempting to adjust my TPS properly, I pulled off oone of the intake manifold hoses, and pulled too far, and the hose was too old and brittle, and it snapped off. Anyone got a part number for this hose? Its the thick black hose that (would) connect to the open port on the drivers side of the intake manifold. Part number anyone?
Old 03-17-2006, 03:38 PM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
I'm in a rush, so I can't bother with it right now.... but this should point you in the right direction if no one else gets it: http://www.subaru-svx.net/photos/fil...czko/30337.pdf
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 03-17-2006, 03:42 PM
Earthworm's Avatar
Meow!
I believe you're referring to part number 807907202 for $7.81 from subaruparts.com
Old 03-17-2006, 05:09 PM
Turns out its part number 807412162. Thanks for the help though guys.
In case anyone cares, its part number 7 here: http://www.subaruparts.com/diag/?mod...category=036-A
Old 03-17-2006, 05:37 PM
Seems I am not so sure anymore. If you take a look at the diagram that I linked in the previous post, and look at part 7 like I specified, that part has hose clamps on the top and bottom of it. However, my hose didnt have hose clamps at all, and didnt appear to need them. I looked up the part number that earthworm specified, and it just took me directly to the price report screen, without seeing a diagram. If I saw a diagram with earthworms part number on it, I would be able to tell if that were the right part. anyone know where I can find a diagram at?
Old 03-17-2006, 05:56 PM
Earthworm's Avatar
Meow!
I got it right from subaruparts.com
Old 03-17-2006, 06:01 PM
http://www.subaruparts.com/diag/?mod...ategory=063-A1
Diagram and part found! It part 7 in this diagram. And its definetly not the one I need. Im pretty sure that the part that I need is the one I found before, the one with the clamps. But then why does that hose in my diagram have hose clamps, but the one on my SVX didnt?
