Old 05-20-2009, 08:37 AM
Green1995SVX's Avatar
Re: Top 5 worst "repairs"- add your favorites!
I will say that the worst repairs we encounter are cases of poorly-done bodywork! Bondo, rivets, spray cans,
Don't forget copies of the Meadville Tribune!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 05-20-2009, 08:48 AM
It's hard to erase memories of the Tribune Method.
Old 05-20-2009, 12:25 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Originally Posted by YourConfused View Post
rear diff repair bushing repair:
that is too funny....yet sad
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 05-20-2009, 01:32 PM
subarufamily subarufamily is offline
tranny flush on a questionable tranny almost sure fire way to have to buy a new tranny
William
Old 05-21-2009, 09:06 AM
PDSides PDSides is offline
Old Guy
"Also, Torque the axle nut, and do it with the wheel on the ground." [/QUOTE]
Doesn't the shop manual call for torquing the axle nut with the wheel OFF the ground? Side forces of the wheel weighted by the car create torque readings that are different than those when the wheel is suspended. Holding the wheel in place while torquing the axle nut with the wheel suspended is a pain in the butt but don't you get a much more accurate reading? Same goes for torque readings with lug nuts. Opinions? Facts?
Old 05-21-2009, 11:19 AM
NiftySVX NiftySVX is offline
Send a message via AIM to NiftySVX
I always snug mine in the air to what is probably around 50 ft lbs and then tighten them with the weight on the bearing, that way everything is in position, but leaving the nut loose in the air and setting the car down would for sure be bad as it would likely seperate the bearing.
2007 GS 450h-Active Stabilizer/Radar cruise
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Toyota Master Diagnostic Technician (former life)
Old 05-21-2009, 12:20 PM
Doesn't the shop manual call for torquing the axle nut with the wheel OFF the ground? Side forces of the wheel weighted by the car create torque readings that are different than those when the wheel is suspended. Holding the wheel in place while torquing the axle nut with the wheel suspended is a pain in the butt but don't you get a much more accurate reading? Same goes for torque readings with lug nuts. Opinions? Facts?[/quote]
Have to agree with Preston here; what the WSM actually says is tighten the axle nut before putting on the wheel. List of instructions is as follows:
  1. be careful not to damage inner oil seal lip
  2. use a new self-locking nut
  3. use a new axle nut
  4. always tighten the axle nut before installing wheel on the vehicle. If wheel is installed and comes in contact with the ground when axle nut is loose, wheel bearings may be damaged.
  5. be sure to tighten axle nut to specified torque. Do not overtighten it as this may damage wheel bearing.
  6. when front drive shaft is to be replaced, also replace inner oil seal with a new one.
  7. after tightening axle nut, lock it securely
Old 05-21-2009, 05:20 PM
Ya, do what the book says. I always use the parking brake to hold the wheel still. And like I said, the nut is already tight before i put it on the ground. It's just easier to keep the car still. if it's tightened to 50 ft lbs in the air the bearing isn't gonna move when you go from 50-130 or whatever the spec is. But for sure do it how the book says.
Then again, I rarely replace the stake nut unless It is unusable, and i beat the hub out with a B-F-Hammer and a socket.
Old 05-21-2009, 06:44 PM
The book is not 100% clear Nifty.
But then, neither were you in your first statement. What you have said above is 100% right for me. Tighten it best as possible in the air. Put on the wheel and torque to correct on the floor.
Old 05-21-2009, 07:16 PM
I just grab my impact and pound the little ****er on till it won't turn no more.
What?
And that's why my car will never be touched by a Canadian Tire mechanic unless I know him really well, or I'm standing 2 feet away. Not that my car goes into other shops anyway...
Old 06-08-2009, 07:15 PM
gbianchi gbianchi is offline
I am sure all of us just could not live without.........wait for it.............climbing under the dash an fighting with the wire harness for hour on end looking for that short/disconnected/broken/whatever, yeah thats my idea of a goood time.......G
I thimk ther4 I an, what? huh!
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
05legacy gt limited "Moon" blue.
06 Subaru legacy gt limited.
Old 06-09-2009, 01:07 AM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
How do you clean stop leak out of your raditor and coolin system
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
Old 06-09-2009, 07:15 AM
You have to flush it several times and hope it comes out. I have had to replace radiators before because it won't come out.
Old 06-12-2009, 06:44 PM
Elliott's Avatar
Elliott Elliott is offline
This was on the shop floor the other day after I did some investigating:
Chunks so big I could put them back together like a puzzle:
They didn't even attempt to pull the dent:
Front of the quarter was munched too under the plastic and the top was full of mud too, I don't have any before pictures though:
Just mocked up in that shot, it is welded on now and that door was also replaced from my parts car. Gap is beautiful, a huge improvement from when I got it, the door used to hit the quarter.
I pulled that rear part out so it is easier to cut off, it came out so easy, if I didn't have a parts car, I could fix it.
Old 06-14-2009, 06:34 AM
scottsubarus's Avatar
scottsubarus scottsubarus is offline
Scottsubarus
R-134A retro fit went smooth on my 92.
I can honestly say it blows colder than any of the other vehicles that I own, and the heater will blow hot air much faster than any other car I own.
