Old 05-29-2007, 06:49 PM
Archer999's Avatar
Archer999 Archer999 is offline
Arrow *Sunroof Drain Tubes
Hello Everyone,
I have located two sunroof drain lines at the front 2 corners of the sunroof. I ran a length of weed eater string down the drain lines, to ensure there was not anything blocking the lines.
After I about 4' to 6' feet down the tube it would just stop. Same thing on the other side.
I could not see it coming out. I think it was hitting the body in the tire well, behind the black plastic.
Here is my question--> Does Anyone Know Where these drains end at? Also, is there 2 more in the back 2 corners?
I have read that most other sunroofs have 4 drains (one in each corner). So I figured this one would be the same.
-Thanks for the help
Old 05-30-2007, 12:42 PM
Good question. I would guess (only a guess) that they exit somewhere in the door jamb, as that's the shortest route to a free draining point. I'll go take a look at mine sometime
Old 05-30-2007, 01:32 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Lines
Here's a diagram.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 05-31-2007, 10:50 PM
Archer999's Avatar
sunroof drain
Hey, thanks for the diagram. I am going to try and get to it this weekend. I will post some pics if everything goes as planned.
Old 05-31-2007, 10:54 PM
Archer999's Avatar
Actually, I got opened your diagram. Where did you get that diagram? That thing is exactly what I needed.
This site rocks. Thanks to this site my car is still running great.
236,646k miles - Go Scuby
Old 05-31-2007, 11:47 PM
That is what this site is all about. Members helping members keep their SVXes running great and doing it without having to spend BIG BUCKS to do it.
Old 06-01-2007, 09:04 AM
lhopp77's Avatar
Shop Manual
The diagram was scanned from the SVX Shop Manual. Actually the shop manual is a set of 4 books for 92 models and addendum books for changes in later years. The set costs approximately $300, but a CD version can be bought for less than $20 on Ebay or a seller on here. The CD version is not as good or convenient as the hard copies, but it will provide most of the information you need.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-01-2007, 04:42 PM
I believe everyone should check their drain tubes to ensure they are not out of place. I had 2 of the 4 pull out of the larger tubes and I believe this contributed to the rust issues I'm dealing with.
Old 06-01-2007, 10:36 PM
The tubes in the trunk are easy to check and if they get pulled out of the bigger tubes, you will get water in the trunk.
Old 06-02-2007, 08:56 PM
XT6Wagon XT6Wagon is offline
thanks, I hope thats the cause of my trunk lake. found one of the ?4? drain hoses in the trunk pulled out. sadly putting it back in didn't give me much hope of it staying. Trying to decide if light pressure from a ziptie will keep it in place or if I need to just go ahead and use a little glue to secure it in.
Old 06-03-2007, 10:52 PM
calisvx calisvx is offline
Wow i checked just see if the hoses were in right i was having water in my trunk ??? which was weird i never thought of this being a problem didnt know they existed well guess what the tube was popped out and there was was tons of junk and black mold all kinds of weird stuff in there it was a h*&^ of a time to clean but thanks to you guys i found my water in the trunk problem
Old 06-04-2007, 12:36 AM
I am glad that was the problem.
Old 06-12-2007, 08:53 PM
Unfortunately by the time I found out these hoses were pulled out on mine the damage was done.
Old 05-29-2013, 10:23 AM
TillamookSVX TillamookSVX is offline
Re: *Sunroof Drain Tubes
Hello everyone. Been searching and reading for days. Trying to get the 'new' SVX maintenance up to date. Soooo....
I looked for the drain holes on the sunroof - in the corners. I can't seem to find them. I do have some vision problems up close... but I didn't think it was that bad. Any 'insight' on exactly where the holes are.
And the previous owner said the trunk leaked. I checked and resealed the taillights. Found the diagram for the draintubes. How do I find where the rubber hose connects in the trunk? Does a panel pull off? How do I pull the panel without breaking tabs?
Thanks for the help. Sorry about the newb syndrome... but I'll get there soon. Ron W.
Old 05-30-2013, 09:08 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Will this parts diagram help?
Gene
[IMG][/IMG]
Gene and Ben
