Go Back   The Subaru SVX World Network > Regional SVX Forum & Clubs > Down Under
Old 10-03-2011, 05:47 PM
spleen_merchant spleen_merchant is offline
Manual swap in Aus?
Does anyone have any experience getting a manual swap performed here? Can someone recommend a mechanic/performance shop who will do this sort of work?
Cheers,
Jeremy.
Old 10-03-2011, 08:51 PM
93tzlegacy 93tzlegacy is offline
Re: Manual swap in Aus?
Cheers,
Jeremy.
while ive never done one, I do own a manual converted SVX and im pretty sure i could replicate it . its quite involved and there is a bit of fab work required with a gearbox mount and a tailshaft, you also need to modify the firewall for the clutch mount, relocate wiring, modift the TC and starter wiring among other things.
Old 10-04-2011, 12:23 PM
I have the whole instructions for the swap someplace if you wold like a look see.
Old 10-04-2011, 07:18 PM
aust92pearl aust92pearl is offline
i would like to see/get a copy of your instructions conn
Old 10-04-2011, 08:14 PM
I think the plan's going to be to order one of the smallcar basic kits from the US and source the rest of the parts here.
Old 10-04-2011, 11:21 PM
oab_au oab_au is offline
This is the manual swaper's Bible.
http://www.subaru-svx.net/photos/fil...k369/19802.doc
One Arm Bloke.
Tell it like it is!
Old 10-05-2011, 01:23 AM
spleen merchant ive heard the small car kits are not the best of quality
and my dad is a welder fabricator and 30+ yrs exp mech as long as we have a fair idea of what needs to be done im sure we can modify whatever needs to be modified ,
thank you oab_au i shall bookmark that link
i still need to find a cheap trans etc or a cheap donor car to get everything il need to do it (hopefully i can find one fairly soon)
Old 10-05-2011, 07:48 AM
I have not heard good things about the small car kit...
Old 10-05-2011, 05:08 PM
You also need to know that our crossmember is different , and our tailshaft is shorter than the US one. You also have to use a US or JDM front Hall Effect speed sensor, that you will have to supply power to, and wire the sensor's output to the speedo.
One Arm Bloke.
Tell it like it is!
Old 10-05-2011, 05:15 PM
Also, this other how-to may be quite useful. It might not be in the how-to docs anymore.
Old 10-05-2011, 07:45 PM
you can use any subaru 3 wire speedo drive, the one in my car is fro man aussie 05 wrx.
Old 10-08-2011, 05:20 AM
Dessertrunner's Avatar
If you go to a 6 speed the tail shaft is the same you only need to mod it when you go to a five speed.
Tony
Old 10-08-2011, 06:43 AM
Tony
i guess il look for a 6 speed wreck then so its a bit easier to put it in ... and i would prefer a 6 speed over a 5 lol
Old 10-08-2011, 10:21 AM
Unless you're planning to get some more power out of the car, then a 6-speed isn't really worth the extra cost. It's also a lot heavier, and the older ones that you're more likely to find for cheap will have shorter 5th and 6th than is ideal in a highway driven SVX.
Not to knock the 6-speed, it's great, but there are trade-offs.
