Power Locks Not Working
So my power locks haven't worked for while now, figured it's finally time to do something about it. Not knowing how power locks actually work I don't even know where to begin.
They don't work either via remote or the lock button inside the car. I have noticed however when trying to lock via the interior button, I can hear a faint clicking. I've checked all the related fuses, and even replace a few that seemed find just to be on the safe side, but no changes. The only other wild card I can think of to mention is that my stock security system has always been a problem for the 6+ years I've had the car. At this point it flat out doesn't arm or disarm via the remote, although it will occasionally go off when I open the door (I guess it armed itself overnight? Spooky. ). I only mention the alarm system because perhaps it's hijacking the power locks and preventing them from working properly? Anyone have any experience with this or general knowledge of how the alarm and lock system are linked up that might be fouling everything up? Thanks in advance! Scott |
Re: Power Locks Not Working
You can eliminate the security module as the issue by disconnecting it, and then jumpering across pins 14 and 15 (orange and orange with a green tracer on it) as those are the only wires in the door lock system that pass through the module. Mind you, these are colors and locations for a 1992, not sure if that changed or what year you have. I attached a screenshot of the door lock system for you.
I'd start with the security module. The earlier ones are supposed to die kind of easily. What year is your car?
Wow, that was a really fast response, thanks guys!
Mine is a '94. I'm glad to hear that the security module might be the culprit and am even more excited at the idea of finally getting that thing out of there. If I'm recalling correctly, the module itself is hidden down under the passenger dash area, right? And quick clarification on "jumper across pins 14 and 15", is there a fuse module or something I can get that will do that, or are we talking about some good ol' fashioned jerry rigging? |
I was referring to pulling the connector and taking a short piece of wire and put it in one contact and then loop it around to the other.
I have a recurring power lock problem on one of my SVXes and it is always due to water in the lock motors. The rubber boot on the actuator arm splits and water running down the inside of the doors seeps into the lock motor.
This is how I fix it every time: Remove the lock, open up the black box, drain the water, spray with WD40 and put it all back together again.
The 94+ have the module in the top panel of the trunk behind a panel that opens. Much easier to get to than the 92s...
Should be able to find one pretty cheap from a part out. A module from any year will work, the location changed, but the modules are interchangeable.
