Quick and easy.
During a compression test, what is the acceptable range of values in PSI?
Thanks, Patrick
171 to 206psi Standard. 142psi limit. 28psi difference between cyl. Harvey.
W.O.T. and all 6 plugs removed...
Is this a wind-up?
How exactly could you turn over an engine to generate pressure in one cylinder with all 6 plugs removed? I had always thought that each cylinder was measured independently, with ignition in the other 5 contributing the motive power. If I am wrong in this, can somebody please explain what turns the cylinders to apply the pressure? Joe
Accepted, but that's a simplistic answer to the question. Assuming the starter motor could turn over the engine, why would you need all six plugs removed, unless you had six discrete pressure readers screwed into each cylinder?
I'm making the assumption that the test involves only one pressure reader. Why not "run" the engine on 5 cylinders?
We just use the starter. Harvey.
Why? Joe
Yes.
I am presuming there is only one pressure reader. Is there a reason why the engine can not run on 5 while one cylinder is being read? If so, explain what problem may be caused? Joe
