Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 09-23-2012, 11:16 AM
'E''s Avatar
'E' 'E' is offline
Re: 6 pot mono block Brembo calliper kit
This is a pic of a 6 pot and 2 pot kit
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 09-23-2012, 11:19 AM
'E''s Avatar
'E' 'E' is offline
And this is the pic of what the 6pot and 4 pot kits looks like
93 black SVX
95 bright red SVX
Old 10-13-2012, 08:40 PM
'E''s Avatar
'E' 'E' is offline
This is the kit fitted to a 2001 twin turbo liberty
93 black SVX
95 bright red SVX
Old 10-13-2012, 08:44 PM
'E''s Avatar
'E' 'E' is offline
From a different angle
93 black SVX
95 bright red SVX
Old 10-13-2012, 08:46 PM
'E''s Avatar
'E' 'E' is offline
One more pic
93 black SVX
95 bright red SVX
Old 11-21-2012, 03:43 AM
'E''s Avatar
'E' 'E' is offline
kit is still cost price for members at AUD$2,500
93 black SVX
95 bright red SVX
Old 11-21-2012, 05:48 AM
I really wish I could pick this up... Unfortunately between the 6MT, body panels, and a new car I've tapped out my toy budget for quite a while.
Old 11-21-2012, 06:24 AM
'E''s Avatar
'E' 'E' is offline
im not going anywhere they'll be here waiting for you when you are ready
93 black SVX
95 bright red SVX
Old 11-21-2012, 08:51 PM
Tireiron Tireiron is offline
As far as fitment under wheels, how much larger are these compared to STi Brembos? I know I'm stuck with 18s for either brake option, but do these require less of an offset or a deeper dished wheel than the STi brembos? (would personally like this setup more even for just the "in your face" factor of the calipers) I need to look into something better to slow me down after a hard pull on a windy road heh.
Old 11-22-2012, 12:44 AM
'E''s Avatar
'E' 'E' is offline
They will suit a 18x8.5 with +42 offset (and maybe a +38 aswell, need to check that) and are about the same size as the sti brembos they just use a bigger arc.
Darin
93 black SVX
95 bright red SVX
Old 11-22-2012, 08:29 AM
Good to know, I'm gonna do my coilovers and brakes in the spring when I build some money back up and will hopefully be using a high offset (possibly a +63, with a 10mm spacer if absolutely needed) and some 265 tires to keep everything tucked inside the fenders. Ill have to do my brakes then test fit some of my friends STi and aftermarket rims to see eactly how much clearance I have. Good to know the radials are the same width as the standard brembos, I always thought the standard brembos were oversized for just a 4 pot caliper.
Is the 2 pot rear setup the same as the STi brembo 2 pot rear calipers? If so then I have an easy source for them to match things up.
Old 11-23-2012, 02:15 AM
'E''s Avatar
'E' 'E' is offline
yes sti brembo 2 pot rears and you'll need sti backing plate, see thread below
http://www.subaru-svx.net/forum/showthread.php?t=57288
Darin
93 black SVX
95 bright red SVX
Old 11-23-2012, 08:03 AM
Yea, I know how the STi 2 pots install, I just wasn't sure if the OEM 6 pot brembo kit used larger rear 2 pots or not.
Old 11-23-2012, 05:29 PM
'E''s Avatar
'E' 'E' is offline
No same 2 pots
93 black SVX
95 bright red SVX
Old 11-23-2012, 07:52 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Here's another vote for a kit that fits 17" rims. Rationale here is that I've already got 9.5 inch wide 17" rims with Hoosier A6 295 tires mounted on them
Great job!
Bill
Retired NASA Rocket Scientist
Center Network Member #989
