Old 09-25-2011, 04:40 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Re: 1995 Brilliand Red SVX L
Congras whit new car.
The car looks grate. And i hope you find out about the fuses.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 09-25-2011, 05:34 PM
jcovey2.5's Avatar
jcovey2.5 jcovey2.5 is offline
thanks man
Old 09-25-2011, 05:35 PM
jcovey2.5's Avatar
Came with the car i an check the records and get back to you
that would be awesome thanks
Old 09-26-2011, 04:34 PM
jcovey2.5's Avatar
Just ordered a Bosch 110amp Alternator today and some 4gauge wire and terminals.
Old 09-26-2011, 11:49 PM
Great find and good buy. Congratulations.
Old 09-27-2011, 06:02 AM
Sorry for the late post My alternator came from a local parts store it was a BBC # AL4328X and it was $302.00
Old 10-08-2011, 05:00 PM
jcovey2.5's Avatar
Just put in a new 110amp alternator and larger wire. Hopefully I can bring it home tomorrow. It stalls as soon as you put it in drive, and I didnt have enough time to look into it. I'm hoping it just needs to relearn idle...
Old 10-08-2011, 05:08 PM
jcovey2.5's Avatar
double post, lost internet connection...
Old 10-09-2011, 06:55 PM
jcovey2.5's Avatar
So can't figure out why it keeps stalling out once I put it into drive... Reverse works fine though. I did rev it a bit and slide into drive to get it moving but once the rpms drop it just stalls out again. I have no idea what would cause this. Also, just like the old alternator the new one gets VERY hot. Anyone have any ideas?
Old 10-13-2011, 08:25 PM
jcovey2.5's Avatar
Did the self diagnosis and came up with Engine Code 38. Which is a short between the TCU and the ECU. Not really sure how to find it...
Old 10-14-2011, 07:36 AM
SVX_MY_BABY's Avatar
Have you let it warm up before putting it in drive? I had that problem after I let mine sit a few months in the winter. After I drove it a few days in a row the problem disappeared. Letting the trans warm up by a long idle helped.
Peter
Old 10-14-2011, 08:44 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Yeah,
1. Turn your car off
2. Take your battery out
3. Have it towed to an automotive electrical shop.
4. Get out the KY jelly.
Under no circumstances should you drive the car, attempt to start the car, listen to the radio in the car until your electrical short has been sorted. Judging from your posts I think this may be something which is beyond your current abilities and if not sorted properly can result in some very nasty things.
Old 11-07-2011, 08:48 AM
apkarian100's Avatar
apkarian100 apkarian100 is offline
Alright guys, I'm helping Joe with his SVX at the moment. We took the TCU out yesterday to inspect what could be wrong with it. We found one of the varistors in the TCU blew. The varistor that blew on the TCU acts as surge protection for the unit as a whole. I think this surge had to do with the alternator causing over-voltage.
I read into alternator problems with the SVX on the this site and there seems to be a voltage regulator for the alternator. If the voltage regulator fails, then the alternator has the potential to deliver up to 17-18 volts to the circuits. This in turn messed up relays and blows fuses.
http://www.subaru-svx.net/forum/show...&highlight=tcu
The fuses on the dash and stereo were blown when Joe bought the car. We replaced the fuses, along with the alternator and the fuses blew again. The alternator currently is connected straight to the positive battery terminal with a fusible link and 4 AWG wire and the original wires were cut and capped together, but I haven't looked yet to see where this voltage regulator would be for the alternator.
Anyone else might know where this voltage regulator is?
Old 11-07-2011, 09:19 AM
From one of the service manual diagrams, it looks like it's inside the alternator.
Old 11-07-2011, 09:21 AM
Ok, I see. So knowing that, I think we'll have to start looking at the alternator wires for corrosion. I also need to check and see if Joe added the necessary larger ground wires too.
