Old 01-06-2010, 10:32 PM
Brandon770's Avatar
Brandon770 Brandon770 is offline
4eat question
Just wondering if a 1997 SVX transmission with a 3:90 gear ratio swap will work in a 1998 Legacy gt.
Old 01-06-2010, 10:50 PM
Re: 4eat question
So you have an SVX 4EAT, that has a 3.90 FDR, a matching rear end?
If so the only thing that you have to check is whether the GT has a spin on oil filter.
If it does they ARE NOT compatable.
If your GT DOES NOT have the spin on filter, then you should be fine, as long as you use the speedometer sensor from the GT.
