Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 03-19-2009, 07:12 PM
gsodonis's Avatar
gsodonis gsodonis is offline
Powder coated goodness! teaser pics
Here are a few teaser caliper pics from Harry's SVX; I just got them back from the powder coater. The pics are a bit dark as I didn't use a flash and the kitchen is dark. I'll be doing the assembly work this weekend and will document the rebuild procedure for a DIY. The next time I do a set, I will take pics during disassembly to complete the DIY.
Anyway, here they are (minus the hardware and all moving parts).
Old 03-19-2009, 07:45 PM
Re: Powder coated goodness! teaser pics
mmm...goodness. Do you have to scrape the powder coating out of the slides/cylinder bores?
Old 03-19-2009, 07:58 PM
gsodonis's Avatar
No scraping necessary - The powder coater plugs all of the threaded holes and the caliper bores. Sometimes he get a bit of powder leakage, but it's thin and pretty easy to remove.
Old 03-19-2009, 08:12 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
Ye Gads (sorry for the pun), They look great!! Can't wait to see the finished product!!!!!
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 03-19-2009, 08:30 PM
Ah, makes sense. I guess the angle of the pictures just made it look like the bores had been coated.
Old 03-22-2009, 11:18 AM
gsodonis's Avatar
Another teaser!
Caliper rebuild In Process.
Old 03-22-2009, 12:05 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
did you check the depth of the threads on the bracket for the bolt that locks the caliper in at the bottom (it's the one that only needs ~25 ft-lbs of torque)? I found that the PO of my Pearlie had helicoiled the hole, which, of course, came out while I was re-doing the brakes. OT sent me another bracket which ended up having a similar problem (no helicoil, just only had 3 threads of engagement) and then YT sent me a bracket that did the trick.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-22-2009, 01:44 PM
newsvx's Avatar
Bill,
Good point. Could you reply back with the specs on the tightening of the bolts - I want to be sure I install them correctly. Most I have pulled off seem like they were over 25 lbs when installed......
Thanks,
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
Old 03-22-2009, 01:45 PM
newsvx's Avatar
[QUOTE=gsodonis;593296]Another teaser!
Looking good, Gads!!!!!
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
Old 03-22-2009, 02:06 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
[QUOTE=newsvx;593330]
Another teaser!
Harry
Just think Harry, at Reading we could cook a set in my garage for you're beauty.
Oh wait, you got more important things to do. You will be missed.
Old 03-22-2009, 02:19 PM
newsvx's Avatar
[QUOTE=benebob;593335]
Thanks, Ben.
I'll really miss being at Reading this year ...... Next year for sure!
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
Old 03-22-2009, 03:25 PM
I think you said before that you were going to write up a How-To on this with pictures of installing the parts. That would be great for rebuilding them if nothing else. I would like to rebuild my calipers myself when they get messed up. Thanks ahead of time.
PS Part numbers would be great too.
Old 04-05-2009, 08:20 PM
gsodonis's Avatar
Further teasers!
Front Calipers are finished!
DIY is in process - a proper DIY takes about 4X - 5X as long as the actual job itself.
First, the pretty pistons with the rust inhibiting coating on the inner bores
New piston sealing rings on their way home
Piston and boot on their way home
New brake bleeder goodness (wearing a proper hat)
The finished beuty
Old 04-05-2009, 08:51 PM
newsvx's Avatar
WOW, they look good!!!! Can't wait to get them, Gads!!
Thanks,
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
Old 04-05-2009, 09:02 PM
I hope you are taking pictures so we can do a How-To.
