Old 09-07-2006, 12:00 PM
Jade Dragon's Avatar
Jade Dragon Jade Dragon is offline
Don't screw with the Dragon
Send a message via AIM to Jade Dragon Send a message via Yahoo to Jade Dragon
wouldnt placing the maf on the pressurized side cause some wierd readings?
->Austin<-
1992 Pearlie (Pearl): motorsport exhaust kit (Wife's)
1994 Red FWD (Roxi): Custom X exhaust
Old 09-07-2006, 01:02 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I checked and they are running the MAF post intercooler....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-07-2006, 02:31 PM
Post intercooler will cause issues with the SVX ECU. Sure you can program a standalone to work that way but... Whenever your recirc valve/blowoff valve is engaged.... bye bye air that has been read and it will screw with your fuel input unless you run your programming to accept this. This is all just BS if you are running on a MAP sensor which then it wouldn't matter
Old 09-07-2006, 03:10 PM
SVXRide's Avatar
Tom,
"Old Tom's" s/c set up is blowing through his MAF without any issues. Not to say there might not be issues at higher levels of boost.
-Bill
Old 09-07-2006, 03:33 PM
Old Tom doesn't have a recirculatory/blowoff valve now does he?
Old 09-07-2006, 03:41 PM
Look at svxtasy's setup in the attached pic...
Old 09-07-2006, 04:38 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
You can actually run it either before or after the maf, as long as its not exposed to extrordinary heat. I prefer not to flirt with disaster although may change it up later.
phil
~Phil
Old 09-07-2006, 10:38 PM
hmmm, i wonder if LAN could make a new codeset to run a MAP verses a MAF.
->Austin<-
Old 09-08-2006, 09:57 PM
Phast SVX's Avatar
there isnt a code that can do that, its a differnt type of system alltogether. You could possibly convert to speed density with a HKS Vein Pressure Converter(designed for a z32 VQ30TT) in an SVX with stage 2 software, but you would neeed to make your own harness and its a lot of work. VPCs are no good without alot of experience and dyno time. They have been the dead end of many projects.
phil
~Phil
Old 09-11-2006, 08:45 AM
SVXRide's Avatar
Update....PhatSuby just posted that he's running a MAP with Hydra...no mention who's tuning the Hydra.
-Bill
