Old 03-20-2009, 05:59 PM
oldss72 oldss72 is offline
Brake caliper boot PN
Hello,
I have the brake caliper rattle problem. I searched and found that this is usually linked to the boot being missing, or the pins being worn. I have found the pin PN's however does anyone know the boot part numbers, and if they are still available?
thanks,
Old 03-20-2009, 07:38 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Brake caliper boot PN
I would just buy a rebuild kit.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-20-2009, 07:46 PM
The re-seal kit for the front is P/N 26297PA010 (~$30/side), and for the rear is 26297AA040 ($20/side). The boots aren't listed separately, only as part of the kits. The kits come with all the boots (3 different ones per caliper), cylinder seals, brake lube...You might as well buy a rebuild kit at this point, you'll probably get all the parts in one shot for less.
