Old 05-31-2007, 05:42 AM
SVX_MY_BABY's Avatar
Manual Transmission Gear Ratio
The STI 6 speed has a top gear ratio of .76, while the SVX auto top ratio is .64. Is there a manual which has a top ratio closer to the .64 or any after market gear kits which would have it? When doing highway miles I want to keep the RPM down when cruising.
Old 05-31-2007, 08:21 AM
Keep also in mind that any manual tranny will have a lower final gear ratio too...so even if you find a tranny with a .64 high gear, it will still be turning more RPMs than the Auto in the SVX.
Old 05-31-2007, 01:52 PM
http://www.subaru-svx.net/forum/show...m+forester+6mt
The JDM Forester STi trans has a 0.707 top gear. Short of getting a custom gear cut, that's about as good as you're going to get.
Old 05-31-2007, 03:33 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Perhaps you shouldn't get a 6mt??? Me thinks a 4.44 is more suitable from what you have indicated thus far.
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 05-31-2007, 03:38 PM
the best 6mt for a cruising ratio is the JDM forester... since they are not easily found I believe the USDM 6mt has a .72 as listed which is very nice... I get 21mpg in my silver with the .86(i think) JDM sti trans I have and thats with a little dipping on the throttle here and then too... So a stock SVX should get closer to 25-28mpg. With the USDM trans it should be right around 30mpg w/ a good running car.
Old 05-31-2007, 05:32 PM
That would be an Auto no? This will be my 4th Tranny. No Auto's. Plus I do like to play the gears on the twisties.
Old 05-31-2007, 08:36 PM
Sov13t's Avatar
Ah okay, yeah manual tranny is just so fun... I just love driving my car... if you do go for 6mt I would recommend to be very careful around E-bay... when I was doing my initial searches I found that about half of the offers on e-bay were scams. Also do remember you are looking at roughly $5,500+ for the entire swap.
Good luck
Old 05-31-2007, 11:41 PM
longassname's Avatar
Just some dude.
I build an auto for $2700 that should last you forever and make your car faster thanks to faster shifts and less drivetrain loss.
Old 06-01-2007, 03:47 AM
Appreciate the offer, but I do really like manual's. The only auto I'd consider would be one with paddle shifts (Or a cheap repair to mine assuming I'm not told to get some peanut butter 'cause it's toast.)
Old 06-01-2007, 03:50 AM
I guess there is really only a couple hundred rpm difference between .76 and .64.
How is the JDM 6 mt different from stock? I see one listed on ebay.
Old 06-01-2007, 08:02 AM
Just some dude.
I was just letting you know that there is an auto that won't break on you option out there. Your forth one comment made it sound like replacing them had left a bad taste in your mouth and was the reason you'd get a manual despite wanting low rpm highway cruising.
Since you actually want a manual because you want a manual........
Get an 07 6 speed. They have the same dif gear ratios as us.
Old 06-01-2007, 10:42 AM
bugman1964 bugman1964 is offline
or just see if some one like ppg has a 5th or 6th gear that would work for you.
Thats what I want to do in my rs is get a 5th gear that will work with my 4.11 rear end to drop my cruise rpm at 70 down closer to 3krpm.
Old 06-01-2007, 10:45 AM
Sov13t's Avatar
I am right around 3k rpm @ 70-73 mph in 6th.
At 3.2k I will be around 80+ mph and so on.
Old 06-01-2007, 01:38 PM
XT6Wagon XT6Wagon is offline
Try looking at the 07 STi or 07? 08? Legacy Spec-B gearboxes as they got new ratio patterns compared to the older ones.
Also might try to find the 3.0 spec-B 6spd stats as sold in europe as this might also have new and interesting ratios.
Old 06-01-2007, 03:35 PM
Just some dude.
umm, do the math with the 3.545 dif gears and I think you'll find the 07 sti is by far the best 6 spd for an svx
