Problem starting
I pulled a code #29 today (Crank Angle Sensor #2). So I pulled both crank sensors and the cam angle sensor, cleaned them all off and checked them (all three measure the same amount of resistance) put it all back in and the engine still wont start. It cranks and acts like its about to start but then dies, it ran once for about a second or two but then same thing. I know the starters good and ive had the battery hooked up to the charger all day. Im thinking about trying to jump it because I read in another thread that the owner was having the same problems and jumping it worked, im also thinking about pulling the timing covers to make sure the belt didnt jump. Any other suggestions? Thanks in advance
Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company Last edited by odepaj; 04-11-2007 at 02:05 PM. |
check the timing belt might have slipped
Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
Checking the sensor resistance is not an exactly definitive test. I can find no data on a the specified resistance, but I would expect this to be quite low, in which case it would be difficult to measure for shorted turns on a comparative basis. What exact figures were you recording? A proper check requires measuring the sensor output waveform with a 'scope. However the low voltage range on a multi meter may provide some indication of an output signal when the engine is cranked. This makeshift check may work best as a bench test by passing a permanent magnet cross the face. An old speaker magnet would be ideal. Also check for a short circuit from either sensor terminal to ground i.e. body of the unit, when disconnected. Also carefully check harness and connections.
All three sensors read exactly the same so (admitting to not being very thorough) I just figured them to be good. Also after cleaning the sensors and clearing the codes, its not throwing the code again (I cleared the codes about 10hrs ago). Im deffinetly not saying its not the sensors, they just seemed to not be the problem now. I'll switch the cam sensors from my '95 to the '92 to see if that works.
Dustin
Believe it or not Dustin, check the water temp sensor.
It has caused this problem before. PS; Thanks Hocrest!
As far as I understand it there are actually two temp sensors. One is just for your temp gauge and the other one lets ecu know the motors temp and such. I believe that is the one that svxfiles was referring to. They are right next to each other on the motor.
