Old 05-04-2007, 09:24 PM
nick_kas nick_kas is offline
thanks. And a big thanks to it's just eric for making people feel like douche bags when they ask questions.
Old 05-04-2007, 11:12 PM
Originally Posted by lhopp77
No matter that you sold Subies---the tires were NOT smaller. All 97 models had smaller tires, but prior to that all were the same. I did not argue about what the documents stated for the weight difference---I said I "thought" it would be more because of all the items I listed.
Find me a single 94 with stock wheels and tires that are smaller. Remember---I owned one. In fact it was the lowest level model ever produced--the LE. (It is still in the family.) On it I could have added the lack of ABS brakes as another weight subtraction. (The ABS pump and toner wheels.)
Lee
Lee,
Actually I was referring to all Subarus,in the 1990- 1995 range, and not just the SVX, THAT WE BOTH LOVE!!!!!
Legacys, Imprezas, yep, thats about it.
In the FWD vs AWD SVX arena it was more like #150s differance.
I would (will) have to check in the literature on the SVX, but with the XT6 AWD vs XT6 FWD I am sure they got at least one tire size smaller, and the FWD Impreza got 13s vs 14s for the AWD.
This is an area that I am personnally unfamiliar with, as I tend to REDUCE my MPG and tire life!
Old 05-04-2007, 11:26 PM
Hi nick
Your idea of actualy changing the transmission from an AWD to a FWD transmission is actually a breath of fresh air.
Most people who want better mpg talk of just installing the FWD fuse.
Where I live, with the winding roads, and bad roads, and snow, and rain , and fox/deer/ wild turkeys etc., awd is a HUGE advantage to an old speed freak like myself!
Its YOUR car, do what you want.
Just realize that once you make it your own , the value is "subject to personal interpitation."
ps, pump up the tires, wax it, tune it, keep off of the gas, take any extras out of the trunk, and drive it like you have no hormones and your mpg will rise.
Old 05-06-2007, 06:53 AM
I don't know if there is any difference in a AWD and a FWD TCU, but would suspect there is...but I know on our 90 Legacy AWD that I pput a FWD tranny in, ran and shifted fine with the AWD TCU still in it....and that is the only experience I have with it...
Old 05-06-2007, 08:28 AM
Huck, there has to be a difference in the AWD vs the FWD TCU.
The AWD one gets speed signals from the front of the transmission and the rear of the transmission. Its software uses differences between these two signals to output different torque to the front or rear, depending which is losing traction.
But, and this is a big BUT, provided the wiring loom [you guys call the looms cords, maybe?] from the FWD replacement transmission is sending the correct appropriate signals to the AWD transmission computer, then it will still be able to do its business, decide when the shifts need to be made relative to roadspeed and demand. Absence of a front/rear speed speed differentiation signal should just leave that part of the software unused, and the FWD tranny should work OK as expected.
It is only in the instance where the fwd transmission being installed is sending different signals from the wiring cords/connectors than the on-board awd computer expects, then shifting will be a problem for this mis-matched combination in this scenario.
This might indicate that the best tranny to get is the one used in the fwd SVX. You would expect they did not use radically different wiring, they would need individual new looms in place, rather than simply leave a few wire redundant.
However, if you buy a Legacy transmission, and know enough about the wiring to determine that it sends the same signals to the same pins as the SVX one does, there should be no mismatch in that case either.
It is do-able for sure.
Old 06-22-2007, 02:58 PM
Minjin Minjin is offline
I have a similar question so I figured I'd resurrect this thead.
My AWD tranny is running in FWD mode due to problems with the transfer clutch. Can I pull the driveshaft until I fix the transmission (if I ever do)? Will the end of the transfer section stay sealed? I haven't eyed it up yet but I figured you guys would know off the top of your head. Any tips?
I'd pull the rear axles as well but I have no desire to disassemble my axles for the stub...
Old 06-22-2007, 06:06 PM
If you pull the driveshaft the oil will leak out of your tranny. You may be able to find a plug though. We did this to our Justy when we were "fixing" the driveshaft joints.
Old 06-22-2007, 07:01 PM
Yes... IF you have the bolt in rear section of driveshaft...in that case you just unbolt the rear section...
Old 06-22-2007, 10:29 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
As someone else posted - if you want to switch to FWD, it's your car - do what makes you happy. However, I see no earthly reason to do such a thing to a Subaru, nor do I see a significant enough gain in MPG to make it remotely worth the effort. Let's see - you go through a lot of time and trouble to end up with a downgraded SVX....
Now, what were you thinking?
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 06-24-2007, 12:46 PM
nonSTOP_service's Avatar
nonSTOP_service nonSTOP_service is offline
206,000 miles on 1 air filter
Send a message via AIM to nonSTOP_service
I'm going to assume he was thinking that he'd get better gas mileage.
Most likely someone mentioned to this kid that AWD's get worse mileage than FWD or RWD cars, and just kinda took it to an extreme. We all know that the time, effort, and money it would take really wouldn't be worth the 2 or 3 mpg gain, but he didn't.
And it was up to us to explain it to him.
But here's an idea. What if he wanted to put the car in an FF only competition and just for the sake of having it, he wanted to make his SVX FF just to throwdown with the plethora of civics and neons kids would be running. God forbid a little bit of originality.
"A car is made to be driven."
1992 Subaru SVX LS-L Scratched Silver Metallic
213,000mi
"Hey what's that green power light mean?"
"It means we're beating that Porsche."
"What Porsche?"
"Look behind us."
"....Nice..."
- actual conversation
