Old 10-13-2013, 02:38 PM
theflystyle's Avatar
Installed the following:
The car is sitting in storage until my garage (and the house attached to it) are finished .
I would recommend one so far based on the amount of current it was able to generate, even on a cloudy day. LINKY
1994 SVX LSi
2008 Legacy 3.0R
Old 10-15-2013, 07:23 PM
How did you hook it up, electricaly?
Old 10-15-2013, 07:51 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
washed and waxed, and ordered new Sneakers for my sti wheels. Went with the Hankook Ventus 437
1995 POLO LSI 76K MILES SOLD
Old 10-16-2013, 08:38 AM
The panel comes with a controller which trickles the charge to the battery. It has a built in 10amp fuse and connects as the middle-man between the battery and the panel.
It also protects the battery from being overcharged which is an important thing to note.
1994 SVX LSi
2008 Legacy 3.0R
Old 10-16-2013, 03:21 PM
Ok, cool.
Most solar chargers just (and I have two instaled, into The Racer and The Claret, one each)
plug into the 'cigarette lighter" socket, which is non functuioning when the key is off.
Old 10-18-2013, 08:29 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Did an oil change today. I usually use Mobil1 synthetic, but Advance Auto had a Quaker State synthetic special deal for $19.99!(5 Qts + filter). I bought an extra Qt and a pint of mystery oil additive.
I have an oil drain valve. It makes changing the oil very clean and easy. The valve is spring loaded but I added a hose clamp just for security
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 10-20-2013, 03:46 PM
processengr's Avatar
New LED doorlight and overhead
A nice upgrade for $15 shipped from DDM Tuning...overhead is their COB panel lamp, comes with adapters for the festoon type of lamp in the SVX. Doorlights are their T-10 LEDS...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 10-25-2013, 02:36 PM
Passed PA inspection again.
Old 10-28-2013, 01:36 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Smile Re: What have you done to your SVX (or other Subaru) today?
Finally installed 90% FULL Polish bushing set - it was an eye opener and got the use of a friendly mechanics 50 ton press ..... got the yellow ones (90SH) - just got the 10 minute mod & 1 minor rear pair to do now.
Also got the R1 Concept slotted & drilled rotors fitted - together with the steel braided brake lines (both from Dayle !! thanks buddy) - just PnP.
Also EBC RedStuff brake pads.
Man what a difference everything makes - the car handles much better, less body roll (still a little squeek every now & then that sure will iron out with age).
The brakes are superb .......
Not sure if I need to even use the Koni inserts that have been sitting in boxes for over 8 years ???
Old 10-28-2013, 01:40 AM
[QUOTE=SURTEESS;729368]Finally installed 90% FULL Polish bushing set - it was an eye opener and got the use of a friendly mechanics 50 ton press ..... got the yellow ones (90SH) - just got the 10 minute mod & 1 minor rear pair to do now.
Man what a difference everything makes - the car handles much better, less body roll (still a little squeek every now & then that sure iron out with age).
Not sure if I need to even use the Koni inserts that have been sitting in boxes for over 8 years ???[/QUOTE]
Yes!
You NEED to install them!
Old 10-28-2013, 11:07 AM
SURTEESS's Avatar
Cool Re: What have you done to your SVX (or other Subaru) today?
ok might install them (the Koni's) over the Xmas period (our summertime)...
Old 10-31-2013, 07:56 AM
New rear brake pads,rotors,and calipers.. Great to have access to a lift.
Old 10-31-2013, 09:21 AM
redlightningsvx's Avatar
Collision Refinishing Tech
RR caliper is locked up chewing my pads to nothing.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 10-31-2013, 05:20 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Gave the Legacy a wash
Then installed new FSB bushings, flashed a stage1 map, and changed the cabin air filter.
-Dustin
Old 10-31-2013, 06:27 PM
If u do put on a new gold iodized x drilled slotted rotor and caliper with new brake pads like I did. Go slow the first few miles. They don't stop to good at first. If you change the caliper do the rotors too. Do both sides.
