opinion on rs coup
I'm thinking of purchasing a 2000 Impreza coup with an 97 sti ra swap, any opinion or advice I should be aware of.
Re: opinion on rs coup
If it's got the STi trans, then it'll have really short, close gearing.
Have a look at this chart: http://www.northursalia.com/techdocs...rannychart.pdf A lot of the 90s STi 5-speeds are not at all highway-friendly. I bet it's a beast on the track though.
Is it a full STI swap? Or just the trans? If it's a full swap, the major factor would be the person that did the swap. Are they able to help work on any problems that arise? Are you able to fix it yourself? Many garages will not want to touch a vehicle with a major swap done.
The local Subaru dealer pissed and moaned when I took Melissa's SVX that has a phase 2 trans in for an alignment.
full drive train the plan for this car will be for the track, Svx is for hwy and cruising
and for the most part I'll be able to work on it myself
Should be a blast in that case.
8500 seems a bit steep?
