Switching temp display from Farenheit to Celsisus?\
I was just wandering if that may be possible..not that i already got almost used with the F degrees display
thanks |
Re: Switching temp display from Farenheit to Celsisus?\
It's actually reasonably simple. There's a connector under the dash that needs to be plugged in, or unplugged...I can't remember the exact details, but that's the idea. I will search.
Edit: Found! Remove the kick panel on the left side of the car. You may have to slide it up a bit to get it out of the door trim. Locate a white electrical connector with a SINGLE black wire going into both sides. Pull apart the white connector. That's it. Put the panel back on, start the car, and turn on your aircon. The temperature is now in celcius!
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 02-03-2009 at 08:30 PM. |
Sweet. I had no idea this was possible. Thanks
In the How-To Docs.
Thanks a MILION!!
this was the quickest fix ever...less then 30 sec )))))).. i've pulled out the panel and the wire "jumped in to my hand"..right in front of my nose ) disconnected and "voila" ! ...-13 C outside ))))))) Thanks again! |
