Old 05-02-2007, 11:07 AM
A new twist on the Manual Swap....
I wanted to try something a little...different...so I made it a 5-speed REAR wheel drive car....with the stock 3.54 LSD rear diff....
SO it keeps the better highway RPMs and is a manual tranny.
I've updated to WRX motor mounts while I was in there, and an Excedy CLutch & PP.
So what do you think...?
I haven't decided if I want to keep it like this, or go back to AWD on it...
(Rear Wheel Burnouts are cool..... ...and I grew up driving Firebirds, which is sort of what it drives like now)
Give me your thoughts...
I've gotten some thoughts from the crew over at XT6.net, but figured this is where I'd get the most response....since it is in a SVX after all
Old 05-02-2007, 11:14 AM
DO IT!
If you go full bore at this, could you remove all of the front wheel drive parts? Axles obviously, but could you also remove the front diff and anything else in the trans that's not needed? A 5MT is already a weight savings over the 4EAT, removing some parts would be even better, plus help the weight distribution.
Old 05-02-2007, 11:17 AM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
You need to post video!!!!
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 05-02-2007, 11:25 AM
I've already done it...no front axles, just stubs in the spindles to hold the bearings together....
Old 05-21-2008, 05:44 AM
SomethingElse's Avatar
word words wording
Does your speedo still work? I thought the front axles drive the R&P gears. What did you use for stubs?
Eric
Old 05-21-2008, 06:39 AM
lechnoid's Avatar
lechnoid lechnoid is offline
Tech & Almost Lawyer
Could you post some pictures from underneath the car? I've been contemplating this sort of setup for my miata project and would love to see some pics.
Old 05-21-2008, 08:05 AM
The front diff still turns, so the speedo still works....
for stubs, I just dissasembled a couple old axles I had laying around and used the outer section to bolt through the hub, to hold the bearings together.
I don't have any pics from under the car...but it's looks the same, other than the lack of front axles....if I have any reason to get under it, I'll try to snap some pics...
Old 05-02-2007, 11:26 AM
Maybe if I put on an old set of tires, so I don't trash my new ones....
Old 05-02-2007, 11:51 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Awesome, i was thinking about something like that, but i have a hundred things to try before. Just a rwd tranny strait back to the rear right?
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 05-02-2007, 12:31 PM
Pretty much, with a locked center diff...
Old 05-02-2007, 08:59 PM
word words wording
you beat me too it ever since the auto rwd ive been wanting a 5 speed rwd to control the shifting becuase the auto will shift into 2nd even when in first so its hard to drive squirly. if only I could stumble on a 5 speed kit.
nice job!
Have you thought about the 4.44 rear end swap?
Eric
Old 05-02-2007, 09:16 PM
thought about it...yes.....but that takes money
I DO have a 3.90 rear diff, that may get built and installed...but for now I'll just leave the 3.54's in
Oh yeah...it'll be at the Dragon Meet in July also
Old 05-02-2007, 03:47 PM
Home thoughts from abroad...
That sure is different Huck. Trust you!! You're a Daddy again. The father of the RWD SVX.
I think you should keep it for a number of reasons. Being unique is one, but it is also only the start.
If you decide to go forced induction, then you should end up with a very quick quarter mile car.
Without going totally "funny car" on it, I think the style of the SVX would lend itself to some sensitive modification at the back.
With all the horsepower now going through the rears, you should now be able to "grow" the rear wheels and give yourself more contact area for traction. Because you are not AWD any more, you could even consider having the rear a taller rolling radius, which also would help your highway RPMs.
[I would also consider a stronger and stiffer rear diff to keep the power down without breaking stuff.]
As you would be going wider with the wheels, this would mean a good excuse to grow the rear wheel-arch bulge. Not to make it an in-yer-face racer or ricer or drift style, just a bigger bulged version of the OEM wing [you guys call them fenders, sorry, forgot].
Oh how beautiful that would look on the road.
I know you work on a budget Huck, but I hope you do it.
Old 05-02-2007, 08:47 PM
It is currently my "Daily Driver" so I don't plan on any real mods to the engine, maybe a Stage I Chip, but that's probably all.
And it's not a 3.90 Legacy Turbo tranny, it's a low milage 3.90 Impreza tranny.
I don't plan on really flogging it, really just an experiment I wanted to to try....so I think everything will hold up alright...I have spare parts for the rear diff, and rear axles if I do break something....
And if I keep liking it, it'll be at the 15th anniv. meet
Old 05-02-2007, 08:55 PM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
Good to hear! I was contemplating going RWD as well, to smoke the tires instead of the trans...
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
