just needa little guidance
So my transmission died. car doesnt go forward or reverse. I'm gonna switch it over to a manual awd. only thing is its a little daunting, and i just really need guidance on what parts ill need. I know basics ill need like the trans itself, shifter, shifter boot, clutch, flywheel, rear diff... but im not sure what else. the car is(was) FWD so im not sure what that changes. but any guidance yall can offer would be much appreciated. like maybe a good source for all the parts. thanks in advance.
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set |
Re: just needa little guidance
custom made transmission crossmember, manual transmission mount, custom made clutch pedal assembly, custom made shift lynkage, AWD crossmember, rear axles, manual transmission starter, pressure plate/clutch cover, clutch cable or hydrolic parts. Lots of time... Lots of money. I am sure I missed some things.
Thanks, Nate.
