Old 05-22-2006, 05:35 AM
mikecg's Avatar
mikecg mikecg is offline
Back to the Track (finally)
Ok peoples, here's the numbers. But first be aware, my S/C belt was slipping and I was only getting 7lbs. So if you get the 7lb pulley from LAN and a 6-speed from Tom, and your a nrebe driver this is what your looking at:
R/T:_____________.691
60':_____________1.883 (spun wheels for a few feet)
330:_____________5.687
1/8:_____________8.915
MPH:____________75.50
1000:___________11.717
1/4:_____________14.088
MPH:____________95.04
I think I could have tough into the 13's with a better launch. LAN is planning on switching to a pulley setup like his high boost one for all the kits to eliminate the potential for slippage.
I a little confused about my trap speed too, Tom's 5-speed had a higher trap speed with a slower E.T.?
Old 05-22-2006, 06:41 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
congrats mike
lets work on getting the traps speeds over 100 they mean a lot,
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 05-22-2006, 07:10 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Excellent time Mike! That 60ft was haulin'!!!! Based on your traps (at both the 1/8 and 1/4) I'd assume some short shifting was going on?
I'd take her all the way to redline to improve your traps. She should be good for at least a 98-100mph trap at 7lbs of boost.
-Chike
2006 Steel Gray WRX TR (sold)
Old 05-22-2006, 07:50 AM
1.883 60 foot, and no giggle gas to refill!
Next time out you are in the 13s for sure!
Old 05-22-2006, 08:49 AM
Chiketkd's Avatar
As well as yourself - Mr. 8lbs of boost!
Old 05-22-2006, 10:08 AM
mikecg's Avatar
1.88 60ft with 4 wheels spinning at the start, so I could probubly get down to 1.5 or so.
I was above 6000rpm for all shifts. 6800 going from 4th to 5th. That's right I was in 5th crossing the line.
I'm attaching the video, I was lined up beside a heavily modded 240sx. You an here his BOV, but the exhaust you hear is all me.
SVX vs. 240SX
Old 05-22-2006, 10:47 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Mike,
Nice! What did that 240 run, something in the 11s?
Keep up the good work - more boost and better tires are going to make a major difference. What size rims/tires did you run?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-22-2006, 11:58 AM
Speedklix's Avatar
Locker Link Solution
Hey fellas... all you need is a stock honda civic to get those better trap speeds
http://videos.streetfire.net/video/2...055934B607.htm
Saw it further down the list and it took a second play for me to understand how he was trying to argue it.
Cool to see you got to make it out again. Sorry about your slippin
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 05-22-2006, 12:47 PM
mikecg's Avatar
Originally Posted by SVXRide
Mike,
-Bill
240 ran 12.729 @ 108.42. The video was from my slower run (14.390 @ 92.40)
I'm running BFG KDW2's I'd either have to switch to slicks or made I can just launch below 4 grand.
Old 05-22-2006, 01:07 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
ok so with mike running sweet time with boost and thinking about running drag slicks... (AKA part brakers) what parts should be expected to go first? CV axles? and what can be done to strengthen them?
- John
Old 05-22-2006, 01:22 PM
mikecg's Avatar
I'm not planning on getting slicks. That was just a statement about how to reduce the wheel spin. I think I'll just launch at a lower RPM next time I go.
and it would probubly be the front shafts. The fronts are stock FWD SVX, the rears are STi ones I believe.
Old 05-22-2006, 01:31 PM
Chiketkd's Avatar
Mike,
Remember that with an awd vehicle, light wheelspin at the launch is good. It keeps the engine from bogging and prevents your drivetrain from taking the full 'shock' when you launch. I'd probably recommend that you go with a 17x8" wheel (e.g. Rota torque, Rota boost) and mount a nice sticky 245/40/17 summer tire (e.g. Azenis RT-615 or Ventus RS-2).
-Chike
Old 05-22-2006, 02:12 PM
LAN is working hard at fixing the belt slip issues and with his current setup, it is as good as it gets from what he said. Mike, I feel that you belt was slipping alot in upper rpms, with the new belt route LAN has designed, you should see an upper 13 say 13.7/13.8 out of her easy at around 100-105. Running more boost you will see those traps increase dramatically but that is all in due time. You are on the right track but like Chike said, some bigger tires on some Rotas would be primo
Old 05-23-2006, 07:14 AM
tom lets not start guessing
lets see what it does and not assume anything untill he does,
but hi 13s is definatly right around the corner,
trapping another 10mph is very very hard to do and takes lots of power 95 to 105
going from 15 psi to 21 psi i only traped another 5-6 mph
Old 05-23-2006, 08:45 AM
poweredx2 poweredx2 is offline
You guys are doing great with those supercharged cars who has one with the auto tranny that car may see a better time and higher trap speed,my hat still goes off I MAY GO BLOWER now,well the first fwd blown svx with nitrous,it will be a just for show.
