Really Bad Gas Milage?
So, last time I got gas I got 14.2mpg. I decided to give it another go just to make sure. I got gas tonight: 12.6mpg. I'm not quite sure to go about diagnosing this one... I don't drive too crazy; I'm assertive, but not enough to warrant that bad of gas milage. I resealed the engine, replaced the water pump, timing belt and pulleys, cylinder heads, 2 of the camshafts, knock sensors, filters.... So I think the engine is okay. I replaced the transmission so that should be okay... What else could cause this bad of gas milage? Thanks
97 Toyota 4Runner SR5, 5 spd 92 Ebony SVX AWD (4.44 gears) |
Re: Really Bad Gas Milage?
o2 sensors?
Is there a way to check if they're bad or do you just replace them and hope for the best?
All I know is that if your going to get them replaced, get the good ones... not the cheap ****. (aka universal) If your willing to put in money in everything else, no need to sacrifice elsewhere or where it helps/counts.
1994 subaru svx le 112k |
Haha, yeah. I'm not about to go cheap after all I've put into this car. I just wanted to know if there is some way to check them before I replace them. And if I do replace them is OEM ($213.28 @subaruparts.com) the way to go or some other brand?
Check codes and see if anything is stored in memory.
I used the $25 ones on ebay which lasted 1 week. Then bought some Denso universals for $60 a piece and they've been great for almost a year now.
Before dropping the cash on the 02s just yet, theres other things that can hurt your mileage. Id first try some good quality injector cleaner thru the system. A binding brake or low pressure in the tires would be a factor. Mine always gets great mileage on the highway, almost 30, but in the city with a cold start every morning im lucky to get what you are. Just a thought, oh and a vacuum leak can also kill mileage, id do a quick once over of your intake tube and see if any of the 600 hoses that go to it were forgotten, it happens (I know).
