Old 08-29-2013, 01:59 PM
The Molinator
Re: RADIATOR... cRaCk!.. HELP!?
I ordered thru Radsus on ebay.. but got a Silla from about 5 miles from my house.. here in Fresno! Ha! I haven't put it in yet.. I'll let you know about fitment.. . SURE LOOKS NEW!!!
Jim
Old 08-29-2013, 02:52 PM
It will fit perfectly and last for years. Just don't order an AC condenser, they're on back order and wont't be available any time soon.
Old 09-03-2013, 01:15 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I ordered from radsus. Had a leak on my first one which they exchanged for me. 2nd radiator is going on it's 4th or 5th year. Would definitely buy from them again.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 09-05-2013, 12:15 PM
The Molinator
Appeared to be exactly the same.. except drain plug had no included tube nipple. Are they remanufactured?
Seems to work too!
Thanks, Jim
Jim
Old 09-15-2013, 07:34 PM
The Molinator
YIKES! .. I'm driving along with my new radiator.. working to go to work for 2 (?) weeks .. ALL OF A SUDDEN .. Overheating.. YIKES! (typical 100 degrees F here in summer)
No radiator leaks
Coolant Overflow Tank full
No cap coolant spray evident
If AC on.. generally worse (or AC temp goes up from 40's and 50's to 80's!)
Gauge going up to red.. then back down near normal.. no obvious reason
But, later when cooler outside (85 degrees F).. still goes up a little with AC off!
Seems the only intermittent explanation.. could be THERMOSTAT???
HELP!!! Any Ideas Appreciated
Jim
Jim
Old 09-16-2013, 05:01 AM
No radiator leaks
Jim
Try a thermostat....but how many miles are on your water pump?
Old 09-16-2013, 01:13 PM
The Molinator
New radiator.. worked fine 2 weeks..
New OEM thermostat at assembly of "rebuilt" engine.. (June)
New water pump..at assembly of low mileage engine (Nate/Pennsylvania-about Feb)
Put new Thermostat in this am with proper rubber gasket seal (thot that was it! Leaking a little under housing (wrong rubber originally!)..
Still overheating on way to work! Gauge @ 1:30 to 2 o'clock .. ???
Could it be the AC causing this?? HELP!!!
Jim
Jim
Old 09-16-2013, 01:43 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I quit using oem tstat's as iv'e have too many over 10 go bad in months. I use the failsafe ones at autozone with oem gasket now with no problems. Also make sure the system is bled properly.
Also are both fans kicking on?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-16-2013, 01:59 PM
The Molinator
About 500 to 1000 miles .. at most!
Jim
Old 09-16-2013, 02:10 PM
The Molinator
I've been out of the car 3 or 4 times when overheating.. both fans on then!
I used an OEM gasket with my old (sitting around, but new) OEM thermostat when putting this engine together about June. Bought an OEM rubber gasket too.. It dint have center groove for thermostat sheet metal (???) .. So I think it caused leak below housing .. not sealed properly.. I just put rubber gasket on top of thermostat, then bolted.. dripping off a little last nite when I was checking around thermostat and looking for other leaks. Got Napa gasket which fits proper.. used Pep Boys Stant small (not OEM size-they make two) thermostat this morning with the proper gasket.. fit good now, but .. STILL STARTED TO OVERHEAT ON MY WAY TO WORK 30 miles away!
What about the air pocket I've been told about?? Is that the bleeding you're talking about? HELP!
Thanks, Jim
Jim
Old 09-16-2013, 08:20 PM
Raise the car about a foot or so in the front, with the motor cooled remove the rad cap and gentle squeeze the upper hose till all bubbles are pretty much gone, then make sure the rad is topped off. After that turn the car on with the heat on MAX with the rad cap off still and let it get to temp which will open the t stat and drop the coolantin the rad slightly. When you see no bubles put the cap on and shut the car off and you should be good.
Seth
Past subies:
Other toys:
Old 09-16-2013, 08:53 PM
The Molinator
Thanks. I did that when filling.. everything, but did not run engine?? I'll try it..
Jim
Jim
Old 09-16-2013, 09:23 PM
What I do is pretty much what redlightning suggested, except I use one of these: http://www.amazon.com/dp/B001A4EAV0/
Put that on where the radiator cap goes, then fill it up and keep some coolant in the funnel. Air will bubble out of it, and coolant will replace the air until there's no air left. The funnel's not necessary but it saves the trouble of having to constantly top off the radiator with coolant. Running the engine definitely helps tremendously with working the air out, by keeping the bubbles circulating until they get out through the funnel/rad fill opening.
Old 09-22-2013, 01:29 PM
The Molinator
Thanks.. After I did it without .. I can see it would be cool!
Jim
Jim
