Old 05-22-2013, 09:08 PM
SUPER SUPER is offline
center brake light?
I have '92 SVX.
Is the center, thin light panel on the trunk under the spoiler supposed to light up as a center or 3rd brake light? Mine does not. I looked in the panel and don't see an easy bulb access point, at least nothing I recognize. Although there seems to be a wire connection point.
Old 05-22-2013, 09:14 PM
reberto reberto is offline
Re: center brake light?
I'm not 100% sure, but I believe that the center light is an LED light, but don't hold me to that.
Old 05-23-2013, 04:31 AM
Yes, the bulbs are not replaceable.
Old 05-23-2013, 04:57 AM
kinz kinz is offline
They are led. Mine didn't work, so I took it out to see if I could find a problem and couldn't. Found one at a pick n pull and bought it. Put it in and it worked perfectly. You should use a multimeter to confirm you have power going to the unit or not.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
